88 E150 300/6cyl EFI Black smoke at idle
My spare van that is not driven often would not start. Started on carb cleaner so traced fault to in tank fuel pump that seized.I replaced the pump.Rail fuel pump ok. engine started ok and runs smooth above idle but would not idle smoothly as before .With a little throttle runs smooth,however it bogs when the throttle is pressed quickly. Very uneven and lopey idle and is blowing black smoke and has turned on check engine light. I cleaned the air bypass,checked the press regulator hose for vacuum no smell or gas evident at the regulator (diaphram not split) Checked hose to map sensor. Its had new wires plugs cap rotor recently unrelated to this issue.The engine has 63000miles. Any help or suggestions appreciated. Thanks
rosadoco
01-09-2020 09:15 PM
fivo2fst4u
07-11-2015 06:13 PM
4EXTRDR
07-15-2011 08:27 AM
