vacuum gauge..... - Ford Truck Enthusiasts Forums
vacuum gauge.....
Old 08-17-2006, 10:11 AM
tgowers's Avatar
tgowers tgowers is offline
tgowers is starting off with a positive reputation.
vacuum gauge.....
i just got an old vacuum gauge(mile-o-meter) off of ebay.... where do i need to run a vacuum line from? i am sure i need to T off from somewhere, but where? i have a 68 f-100, with a 360 and a 2 barrel carb.... but i am asking on this forum because i am hoping someone here may have used one on an older vehicle.... the gauge is from the 40's. thanks, tony
Old 08-18-2006, 12:46 AM
45ford's Avatar
45ford 45ford is offline
45ford is starting off with a positive reputation.
I've got one in my 60 F-100 panel with a 5.0. It's plumbed into the vacuum port in intake behind the carb that provides vacuum to the automatic transmission.
Mike
Old 08-24-2006, 11:50 PM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
Any vacuum port at the base of your carburetor is a good source for engine vacuum. If there is not an unused one, you could use a plastic T to tap into a hose.
0401 code bobbydee 1997 - 2003 F150 0 10-21-2016 03:39 PM
Vacuum Gauge - Manifold Vacuum - Carb Tuning treverd 1967 - 1972 F-100 & Larger F-Series Trucks 12 01-22-2016 03:39 PM
Where do I connect a vacuum gauge and tach for tuning? Funke1 Ford Inline Six, 200, 250, 4.9L / 300 11 03-22-2014 08:47 PM
How to Set Mixture with Vacuum Gauge?? bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-16-2012 09:38 AM
Where's my vacuum line? F350kid 1999 - 2003 7.3L Power Stroke Diesel 2 08-03-2010 02:53 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
gauge, meter, mile, mileometer, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
