Titration Test
Titration Test
Getting ready to make a second batch of biodiesel. Did my titration and came up with 4 tenths of a milliter to reach a ph of 8. The test was the same last time I made a batch.I'm using peanut oil from local resturaunt that only cooks in it for three nights a week. Just wanted to see if anyone else has ever titrated oil this low. I would also like some input on mist washing .
I wouldn't think even pure veggie oil would titrate that low, but then again peanut oil is a higher quality.. I mist wash, Just lightly mist the first time then step it up with a bubbler on the second go around. After that I drop a heater in there for about 2 hrs or leave it in the sun. I let it sit afterwards for about 2 days just to make sure everything dropped out (soap and water) Also whats your base on titration? Your doing 5 as your base?
Originally Posted by kennedyford
Standard formula if your not a tree hugger and trying to save every single penny you have is....25 gallons oil, 5 gallons methanol, and 3lb of Koh or if your still using sodium 2 lbs. Heat oil 150 and add the contents of methaloxide and mix for one hour. Drain to holding tank and wait.
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
16
01-14-2015 10:15 PM
whiteaddiction
02-02-2009 12:02 AM
AndysFords
09-25-2008 12:30 PM
Gun-Driver
08-19-2008 07:33 AM
6.0superduty
03-19-2008 11:44 AM
