Valve Lash on a 390 with adjustable rockers - Ford Truck Enthusiasts Forums
Old 05-25-2002, 07:41 AM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
Old 05-25-2002, 10:29 AM
huitt24 huitt24 is offline
huitt24 is starting off with a positive reputation.
Does anybody have the correct procedure to adjust the valve lash on a 390 with adjustable rockers? I have tried to adjust them they way I would my old "C" but run out of adjustment. Is there a perticular amount of lash when the lifter is collapsed or is there just a 1 turn after contact is made adjustment? Any info would be great as I am stuck at this point. It is a 390 with 427 adjustable rockers and hydraulic cam.
Thanks
Jack
66 F250 Camper Special Custom Cab 390 4spd PS/PB
Old 05-25-2002, 02:11 PM
Jack: I seriously question the wisdom of using adjustable rockers on a hydraulic cam. If you mean also that you are using hydraulic lifters (HDLs from here out) AND adjustable rockers (ARs from here out), in my gentle opinion (pardon the pun) you're off your're rocker - literally. You cannot use successfully, for long, adjustable rockers and hydraulic lifters together!
Stop and think about it. HDLs take out any lash by compensating for wear, but ARs allow for expansion caused by heat - the 2 cannot co-exist.
Historically, 427s used ARs only for a few earlier applications, and later went to HDLs.
Tell us a little more about your setup (engine wise), and what your reasoning is for doing it this way.
Old 05-25-2002, 02:17 PM
Jack: An additional thought: Do you have a PI block? If so, you will NEED to run adjustable rockers, but that will require a NON-hydraulic cam. Otherwise, it's best run either a hydraulic sysem or a non-hydraulic system - but not a mix.
Old 05-25-2002, 02:48 PM
I have a rebuilt 390 block that the heads were milled that I dont know how much. I had problems getting the intake to fit which means to me I would need shorter pushrods so, instead of trying to figure out what size push rod I needed I would go hydraulic lifters and adjustable rockers similar to what the small block has. That is why I went this route. should I go back to the non adjustable's ?
Old 05-25-2002, 02:50 PM
merc460 merc460 is offline
merc460 is starting off with a positive reputation.
Here is what I have done when running a hyd cam with adjustable rockers make sure the number one cly is at TDC and not in valve overlap.Then turn the rocker arm adjuster nut down just until you can with your fingers turn the push rod with a slight drag, then turn the rocker arm adjuster nut another 180 or half a turn, roll the engine over to the next cly ready to fire on TDC and repeat. Eric
Old 05-25-2002, 08:44 PM
bmoran bmoran is offline
bmoran is starting off with a positive reputation.
Eric's right on his method of valve adjustment -- one thing noone has mentioned is that you can screw up your valve geometry when you mill your heads. When you change the dimension from the rocker centerline to the camshaft you change the angle of the rocker and the actual lift of the valve in relation to the lift of the cam.
If the heads have been milled <.010 - probably not a big deal. If they've been milled .030 or more you may need to check it.
Old 05-26-2002, 06:20 AM
Jack: Bill and Eric have given you excellent advice.
Bill is absolutely correct about the head milling, and it depends on how much. On one hand, the geometry does change at milling, and can have an effect. It really depends on the heads and the block.
Also, hydraulic lifters have that built-in clearance capability, so unless you mill more that about .030, you shouldn't have to worry about the pushrod length.
Now, if put in USED (well used, that is, with many many miles on them) hydraulic lifters after milling the head, you may end up with stuck lifters. That happens because the shorter distance makes the pushrod collapse the lifter further into the barrel, and any oil sludge there may make the plunger stick. So, after milling heads, always install new lifters.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
390, adjust, adjustable, adjustment, arm, engines, fe, ford, hydraulic, lash, rocker, rockers, setting, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
