Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-16-2006, 06:26 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Wondering why your MIL doesn't come on?
Ever wonder why your MIL/CES light doesn't come on for certain things?
Misfires, dirty MAF, bad IAC?
Many trucks over 8500lbs only have OBD-I not OBD-II.
Same computer, same communications, but certainly a different threshold for certain things, and other things are just plain gone.
This is from 2001:
For the rest of the years, go here:
http://www.motorcraftservice.com/vdi...&menuIndex1=56
In the sheet for 2005, Ford mentions phasing in OBD-II in trucks, and some Federal spec trucks may still be OBD-I.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #2 (permalink)
Old 08-16-2006, 09:51 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Art ,you should sticky this in all 4 forums
sd,x,v10,v8
Also its agood reason to have a good scanner.
we've known for awhile as techs .
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #3 (permalink)
Old 08-17-2006, 04:49 PM
Houndog101 Houndog101 is offline
Houndog101 is starting off with a positive reputation.
Is this a good thing or bad,, why did they do it this way ?
Thanks,, Ted O.
__________________
2000 Black Lightning
98 Pace Arrow Vision motorhome, 37', F53, V10.
98 Eddie Baur Expedition
http://www.ford-trucks.com/forums/cu...ar202008_2.gif
  #4 (permalink)
Old 08-17-2006, 05:17 PM
Krewat's Avatar
Quote:
Thanks,, Ted O.
Because they didn't need to. I guess it's cheaper. Maybe they'd get less emissions warranty claims if certain things that didn't need to be checked on >8500lbs vehicles didn't light the MIL?
I wonder if "functional tests" require certain amounts of circuitry, and if they don't need to do it "by law", then the heck with it?
For instance, functional testing of the IAC - why not? It's probably required in OBD-II, but it would be nice to have in the trucks too.
__________________
  #5 (permalink)
Old 08-17-2006, 09:29 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Thanks,, Ted O.
It's really not good or bad, it's just a difference that must be accounted for when dealing with the heavier trucks.
Since they don't have to meet the stricter emissions requirements of the lighter trucks, Ford just used the same PCM as the lighter trucks but with programming "not implemented" for certain functions.
Steve
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #6 (permalink)
Old 09-06-2006, 07:22 AM
metrovic metrovic is offline
metrovic is starting off with a positive reputation.
2003 E-250, 8600 Gvw, Obd-ii.
  #7 (permalink)
Old 09-19-2006, 04:44 PM
350z 350z is offline
350z is starting off with a positive reputation.
04 f350 , 9900 gvwr , obd -I.
__________________
04 F350 5.4l auto 4x4 sc sb lariat,buckets,4.10LS, plow,camper/overload springs/rear sway bar,FX4,pwr pedals&slider,backup sensors,heated/lighted mirrors,cab lights,Gibson stainless exhaust,FTVB,6"superlift w/diesel
springs,35's,bilstein5100's,alarm/remote/pager,undercover,spd y pipe.
  #8 (permalink)
Old 03-19-2007, 04:13 PM
Krewat's Avatar
Bump... good information for all ... explains a lot about why things can go wrong on these motors and never light the MIL.
__________________
  #9 (permalink)
Old 03-19-2007, 04:19 PM
I noticed the rear o2's are disabled at the factory for the 03 E-250.
  #10 (permalink)
Old 03-19-2007, 04:46 PM
Fredvon4's Avatar
Fredvon4 Fredvon4 is offline
Fredvon4 has a good reputation on FTE. Fredvon4 has a good reputation on FTE.
The way I read it---- MY 2004 and up have "phased in OBD II" for 8500 lb and higher vehicles
Because of the CAN interface and the massive changes to my cats and evaporative system on the 2005 F350 I believe it is fully OBD II compliant and sensored
__________________
  #11 (permalink)
Old 05-03-2007, 05:43 AM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE. 1 is gaining momentum as a positive member of FTE.
Just got to this thread througha link from another post.
One big benefit of this in sttes liek illinois that only test 96 nd newer OBDII vehicles for emissions can be either an eemption if its OBDI?? Or if they can still scan it there re fr fewer codes that cn be tripped and make you fail the test. If im OBDI ill probably stop by the emissions tes station and ask some Qs since its right down the street from me.
My excursion is rated at 88 or 8900 GVWR i gotta try and figure out if its OBDI or II somehow though hummm....
Were the OBDI Equipped trucks sent out of the factory with no rear 02 sensor? That may be a quick way to look under the truck and know what you have.
  #12 (permalink)
Old 05-03-2007, 09:32 AM
juterbock juterbock is offline
juterbock is starting off with a positive reputation.
This explains why in NC I didn't have an emissions test on my '01 F250, just a $8 safety inspection, my wifes van gets a $40 inspection. I guess there are some cost savings on bigger trucks. The other wierd thing I noticed here in NC is that almost all 3/4 ton trucks and larger and alot extended cab 1/2ton trucks have weighted plates, and I don't, never have figured this out.
  #13 (permalink)
Old 05-03-2007, 10:13 AM
Krewat's Avatar
One thing about inspections is, if you are registered as a passenger car, you WILL fail the test. I had problems EVERY year since I got the thing brand-new in 2002, either because the guy didn't want to put it on his "dyno" emissions equipment, or the thing failed the OBD-II tests. The last test, they just told the inspector to put it in as 8800lbs (instead of the 5700 on the registration) and it needed an idle sniffer test.
But yes, this does effect inspections.
Look under the hood for the emissions sticker. It will say "conforms to XXX for heavy-duty truck engines". My says "Conforms to ULEV specs for heavy-duty truck engines". The key part is "heavy-duty". If it says that, chances are you are OBD-I
The third O2 sensor is NOT an indicator that you are OBD-I or OBD-II. That's just for checking catalytic converter efficiency, and it doesn't mean anything OBD-I vs. OBD-II.
__________________
  #14 (permalink)
Old 05-03-2007, 11:40 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE. Big Orn has a very good reputation on FTE. Big Orn has a very good reputation on FTE.
Good info and good post, Art.
Why is this not a sticky?
__________________
Staring too long at your own navel leaves one only to stare at the difference in another’s. The reaction to that difference tells much about one’s inability to stare at own navel. - krewat 2006
  #15 (permalink)
Old 05-03-2007, 11:49 AM
Krewat's Avatar
Quote:
It was. We are strongly encouraged not to post stickies anymore, so it was un-stuck
It should be turned into a tech article, but ... haven't had the time lately. One of the bad side-effects of having money-making work - you gotta WORK!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
