Just played with Proscan 5.2 on my EX and it is OBD1.
Shows only O2 sensor bank 1 and proscan tells me that the vehicle is not ready to
share info for bank2.It will show limited data but half of the Proscan sensors are dead.
It shows bank1 and bank2 fuel metering and they look similar so I guess O2 sensors are working.
Is there a way to exchange PCM-OBD1 with PCM-OBD2,or maybe reprogram it to OBD2?
Because they didn't need to. I guess it's cheaper. Maybe they'd get less emissions warranty claims if certain things that didn't need to be checked on >8500lbs vehicles didn't light the MIL?
I wonder if "functional tests" require certain amounts of circuitry, and if they don't need to do it "by law", then the heck with it?
For instance, functional testing of the IAC - why not? It's probably required in OBD-II, but it would be nice to have in the trucks too.
Both KOER and KOEO tests will run on our V10's. This isn't really an OBDII or OBDI thing, and both tests are for the most part system and electrical continuity tests. As far as I know, you need a Ford Scan Tool (NGS, WDS) in order to run these.
Tahnks for this information. It helped me to look at my problem in a different way. Also thank you for your response and direction with my problem.
Mathew
Hi, guys; I said last week that my 03 F350 auto didn't have a sensor after the cat and it is a CA emissions truck. It does. It's a couple feet behind the cat and I never saw it b4. Does that mean my truck has the OBDll?
