Brake Light Switch Stock 6 Volt - Ford Truck Enthusiasts Forums
Old 08-15-2006, 10:24 PM
5 Star's Avatar
5 Star 5 Star is offline
5 Star is starting off with a positive reputation.
Does any one have any input on this topic?
A friend of mine was told by another guy that the Halogen Bulbs that are recomended by various parts sources to be used in the Panel Trucks, can burn out your Brake Light Switch.
I recently bought a pair of these 6 Volt Lamps for a friend of mine as his Tail Lights were very dim at night. These were a great addition to his vehicle and work just fine, and now his Ride can be seen by others.
He was recently told by another that they will burn out Brake Light Switches. I myself can't see why, but is it possible?
Old 08-15-2006, 10:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Unless the halogens are a much higher wattage, I can't see how they would affect the brake light switch or the turn signal switch. Are these halogens made specifically for 6v? Halogens are very voltage sensitive. If the rest of the system is not 100%, especially grounds, they won't last.
Old 08-16-2006, 10:11 AM
5 Star's Avatar
I got these from Nifty Fifties, and their catalogue, although I don't have it right in front of me to read word for word. States that these are recomended for the Panel Trucks with the metal caseing and glass lens. Not recomended for plastic lens tail lights, because of heat generated, from these lamps.
Also yes they are made for the 6 Volt powered systems. Most of the early Panel trucks that I can remember "Ford", used the same lamp as the 41 Ford car, right on into the fiftys.
I bought these lights for use on a 46-48 Ford car. These lights are basically the same construction as the panel Trucks, with a slightly minor lens and body design, both have the steel body and glass lens.
Old 08-16-2006, 09:14 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
First, turn off the bold type, we aint blind or deaf!
Halogens run higher wattage but that shouldnt bother the old style MS mounted switch as they are plenty beefy internally. At least good ones from Standard are, cant say about cheappo imports.
Couple of questions on a (possible) 76 F-100 Flying Monkey 1973 - 1979 F-100 & Larger F-Series Trucks 25 12-09-2014 10:46 PM
Wiring delimna maples01 1968-2013 Full Size Vans 6 11-02-2014 08:24 PM
Here's how to switch 6 to 12 volts frogmun's 55 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-15-2007 09:56 AM
53 F100 6Volt Gauge Problems 53redford 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 05-21-2006 02:30 PM
Headlight Wiring Problems, Help! Third Coast 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-28-2004 02:43 PM
Tags
1948, 1952, 1960, 6v, brake, brakelight, f1, ford, light, lites, signal, switch, triumph, truck, turn, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
