Pyrometer not functioning
Old 08-19-2006, 06:01 PM
FARM69's Avatar
FARM69
FARM69 is offline
I just installed a autometer pyro on my PSD and to my surprise the pyro does not work. It has power, the ground is good. The sensor harness is fine. It doesn't even calibrate itself to zero when I turn the key. Did I do something wrong? Has anyone ever had this problem. I claiming the gauge is faulty. Any suggestions?
Old 08-19-2006, 10:12 PM
1997F-350's Avatar
1997F-350
1997F-350 is offline
pyro power should be tapped into the #17 fuse and the light #10.
did you hook the two wires to the right ones with the little bolts that goes under the heat shrink? i think its red and yellow.red to red and yellow to yellow.
since it doesnt come up to the temp i would think its not getting power.
check your wires on the back of the gauge also.
Old 08-19-2006, 10:29 PM
FARM69's Avatar
FARM69
FARM69 is offline
little bolts? I don't believe there was any little bolts. I've checked the plug and its snapped in place in the back of the gauge. I thought the wires went straight thru - the plug to the probe? My constant power is coming off the ignition wire... does it matter if its not on #17? I'll have to look at it tomorrow.
Old 08-19-2006, 10:37 PM
1997F-350's Avatar
1997F-350
hmm
maybe autometer has changed their design or you got some fancier gauges.
also sounds the wire to the probe is different than mine also.
the way mine is was the probe with about 10"(roughly of wire coming off of it) from those two wires i had to connect to the long wire that went to the gauge. dont sweat it if yours is different.
doesnt sound like your gauge has power. i would run a fuse tap off of #17 for the pyro. and #10 for the lights for all the gauges you have. these also work with the dimmer when done like this. they will dim when you turn the dimmer just like the instrument cluster does.
Old 08-20-2006, 07:22 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Autometer had a problem a while back. Maybe your's is one of them.
Take a look at these: (hope the links work)
https://www.ford-trucks.com/forums/5...nctioning.html
https://www.ford-trucks.com/forums/5...autometer+pyro
Old 08-20-2006, 01:51 PM
FARM69's Avatar
FARM69
FARM69 is offline
Well guys, I just rechecked and redid all the wiring for the gauge and still no luck. I don't know what else to try. I'm stumped. I guess I will try to get a hold of autometer and see what they say. All my other gauges work fine. I'm pretty bummed about it though. Thanks for the help though.
Old 08-20-2006, 03:52 PM
1997F-350's Avatar
1997F-350
autometer has a pretty good warranty. send it in after you call them and you will have a new replacement asap.
