Removing water spots from auto glass?
#61
Anybody out there have any suggestions that acutually work for removing water spots from auto glass? I've researched the topic on the internet and have tried some of these methods but nothing has worked. Things I've tried include Bon Ami, white distilled vinegar and 0000 steel wool. After trying all of these things the spots are still there. Any help/suggestions with proven methods would be appreciated.
#62
This worked for me, "BAR KEEPERS FRIEND". I found it by the Comet at the local Wal-Mart. I mix it with water in a bowl and made a paste out of it. I used a towel and rub it on the wet windshield in a waxing motion. I later sprayed it off and Bada Bing, no spots ! Like others, I have tried vinegar, CLR , scotch bright pads etc.. This took me about 20 min using no more effort than normal waxing.
#63
Cerama Bryte ceramic cook top cleaner does an excellent job at removing hard water stains from automotive glass. Use with a terry cloth pad on a buffing machine.
Cerama Bryte
Cerama Bryte
#64
I have used a couple products from CR Laurence with great success. The one iin particular is very easy to use and you can rinse it off. I will get the exact name and part numbers when the website straightens out. From my experience, it seems like some glass forms a "skin" on it, especially windshields, and water attacks or eats into it and etches the "skin". You can also feel the "skin" because when you wash the windshield, you , or at least I, feel a difference when I wipe from the area where the wipers pass to where they don't pass. The area where they don't pass seems to be grittier or rougher. Just my observation. ut the CRL stuff works great.
#65
Hard Water Spots
I was recently introduced to Ducky Products 'Water Spot Remover for Glass', they have several water spot removal product depending on the severity, this product is no joke. Did a side-by-side comparison to Mothers and this stuff ran circles around mothers. I was able to get spots off that have been on my glass widows for years. I also started using their Quick Clean & Wax product...awesome stuff.
#66
#67
#69
I detailed cars in Florida for dealerships for many years. The water where i lived was extemely hard. I've done a few that people left a car near a sprinkler for weeks and the windows looked like shower glass, you couldn't even see through them. I'll tell you how to get it completely off, but you need to use extreme caution as its easy to screw the car up if you are not careful. You need acid wheel cleaner. Professional detailers use this and would prob sell you a bottle. Make sure its diluted, its very strong. You need to get a hard bug sponge, the ones we used were called bug blocks and were yellow. The whole time you are doing this its very important to keep rinsing the car off. Spray the acid on the wet window and scrub with the bug block, again keep rinsing.. also DO NOT put acid on the windshield. Windshields have some kind of coating on them and they will fog up permanently. So rinse, mist acid scrub rinse. Its takes a long time but works. The acid will not hurt your paint unless it gets left on it. I used to acid wash vehicles also.
Nitro901
01-06-2017 11:35 AM
fixit5561
1997-2006 Expedition & Navigator
06-13-2016 07:26 AM
