Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Alaska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alaska Chapter Join Chapter, Leader: bearman113
  #1 (permalink)
Old 08-14-2006, 09:40 PM
WilliesSD250's Avatar
WilliesSD250 WilliesSD250 is offline
Garage is empty, add now
WilliesSD250 is gaining momentum as a positive member of FTE.
Well it's finally done.......
Well after having the parts lying around, I finally got my O.E.M. roof marker lights installed. A friend of mine needed a deck built...he had the materials so we swapped labor. I was able to take pics of his progress...I'll post them when I get some time, but talk about scary....seeing all those holes drilled into the roof of my truck made me almost sick to my stomach. But it's done and I just can't stop drooling now. First night I got them done I turned on the lights at dark and just looked at them for an hour in amazement
Also got the zoodad mod done too!
__________________
It's not the length of life, but the depth of life.
  #2 (permalink)
Old 08-15-2006, 12:30 AM
mlb4966's Avatar
mlb4966 mlb4966 is offline
2011 Yamaha MTX
mlb4966 is starting off with a positive reputation.
Ok I have to ask what is the zoodad mod???
__________________
Mike B
1999 F350 CC DW 2V V10 - 2000 F350 CC - Flatbed 7.3
2002 F250 SC - V10 - 2004 F350 CC - 6.O (Terd-Injectors)
2006 F350 CC Lariat - 6.0 (Terd 2 - Head Gasket)
2011 F350 CC 6.2 - The future shall tell
  #3 (permalink)
Old 08-15-2006, 12:57 AM
It's that hole you cut in the radiator support in front of the air intake tube. I drilled two large holes sorta at an angle to each other and then turned the two holes into one long oval hole. It allows more cooler air into the air filer and then the engine. This mod helps to lower your EGT's.
If you go to the 6.0 forum there's a thread going now on the ZOODAD mod. Also links to pics on how it's done.
Heree's the link Mike....http://www.ford-trucks.com/forums/51...d-mod-wow.html
It's really easy to do, only take about 15 to 30 minutes from start to finish.
Mike, I should be closing AGAIN on my house here very soon...possibly even the end of this week. Hope to have your $$$$ to you shortly.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
