Coolant flow through a 4.6
Basically, the water pump pushes water into the water jacket at the front of the motor, it travels down around the cylinders to the back of the motor, then up the back into the heads, and then to the front where it comes out the heads and goes into the intake crossover, and then out the thermostat to the radiator.
The heater core is fed from the back of the motor where the water passes up into the head, and then that is routed back to the intake crossover area. At least, for the 4.6's I've seen.
That's a simplistic view.
Why do you ask?
Why do you ask?
The reason I ask is this. Af friend bought a 95 Cougar w/the 4.6 in it. It had water in the oil so he suspitioned it was the oil filter housing? gasket. He changed it and it was bad. However, when he starts to fill it the water still runs out of the pan. So, I was wondering if there were any parts, aside from the block, that could go bad in the lower end. By the way, the car runs but does NOT smoke like a head gasket. Any clues? Thanks in advance.
Check behind the water pump, and see if the timing cover is eaten through, or broken, or something like that. Otherwise, maybe a gasket went bad where the timing cover meets the block. It's gotta be something at the timing cover, if it's just pouring out of the pan like that.
I guess it's always possible the bottom edge of the water jacket cracked and it's going in there, but check the cheap stuff first
Originally Posted by LxMan1
Doesn't the waterpump go directly into the block on a Mod engine? The timing cover goes beside the pump.
And the lower radiator hose goes onto an extension that bolts right to the side of the block.
So WHY is water pouring out the oil pan?
Not necessarily
If coolant is leaking out of the manifold, it will find it's way down through the block, via the valley,and then into the pan. If there are no other obvious signs of coolant loss, I am willing to bet it is the crossover.
As a sanity check, go to a junkyard...err...automotive recycling center...and try to find a good 4.6L intake on that vintage.
Help!
Why do you ask?
Why do you ask?
I dropped a nut down in the water jacket opening right behind the thermostat opening andI can't get it.
Zoidberg
Modular V8 (4.6L, 5.4L)
05-27-2017 08:59 AM
