New to Diesel - Ford Truck Enthusiasts Forums
New to Diesel
Old 08-14-2006, 03:14 PM
zamboni250's Avatar
zamboni250 zamboni250 is offline
zamboni250 is starting off with a positive reputation.
New to Diesel
I have recently traded my F250 460 for a 7.3L Powerstroke and am interested in BioDiesel. I am not ready to make it myself but would like to buy it as opposed to PetroDiesel. My question is this: Can I burn B20 without any modifications to my truck? What are the negatives? Any input would be great.
Thanks in advance.
Old 08-14-2006, 04:24 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Depending on the model year of your truck you can run B(anything) without mods.
Most PSDs were made with fuel lines, and other rubber like fuel system components, that are safe for BD. I believe the cut off for BD safe models is 1994, pre is unsafe and post is safe, I could be wrong on the year.
Bio is cleaner burning, environmentally friendly, makes your truck run quieter and smoother, and if you make your own significantly less expensive.
Old 08-15-2006, 02:54 PM
zamboni250's Avatar
My new to me truck is an 02 F350 4x4 CC LB. Thanks for the info. I will start reading up on making my own.
Old 08-15-2006, 09:47 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
B20 will work fine in your truck. If you have any factory warranty left be advised that Ford only permits the use of a maximum of B5.....though I think they would have and exceptionally hard time proving you used more, if they could tell at all.
Old 08-15-2006, 10:01 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
The only downside to running B20 or higher is it will clean out your fuel system as bio is a great solvent. So if your going to run it carry an extra couple of fuel filters because your going to clog the first couple up, but once your fuel tank is cleaned out it will be fine. I stated down side and it is because of having to change the filters but it's also a major up side in that now your injectors, lines, pump etc are all nice and clean and working much better.
Biodiesel PSDiesel911 1999 - 2003 7.3L Power Stroke Diesel 17 06-05-2008 12:37 PM
Biodiesel in a 08 6.4 stroker roland New Member Introductions 1 02-17-2008 07:20 PM
How to Make Bio Diesel turboman24 Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 09-24-2007 01:45 PM
Where can I get the best kit to make biodiesel? captaincook Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 05-27-2007 11:44 PM
Is Biodiesel OK? esmarkey Bio-diesel, Propane & Alternative Diesel Engine Fuels 25 03-08-2006 07:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
