GEM module problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
GEM module problem
Old 08-14-2006, 12:24 PM
fyrmnk1 fyrmnk1 is offline
fyrmnk1 is starting off with a positive reputation.
GEM module problem
Hi all, I posted a while back about multiple gremlins dealing with the electrical in my truck. A response thought then it might be the GEM. Now it's really flared up with some new things so I thought I'd post it all here again and see if the GEM could cause all this. Wanted to double check before I shell out $400+ for the module.
All the upcoming things happen with the key off, intermittently, and only after it rains:
Fan blower stays on
Radio clock stays on
Windshield wipers kick on
Locks lock and unlock repeatedly
New today, the horn activated and stayed on solid until I went out and opened the door
Also occasionally the speedometer and odometer will stop working while I'm driving, or bounce all over the place.
Once it dries out outside, all goes back to normal. I've reached up all over behind the dash and can't feel where any moisture is coming in.
Thanks in advance for any input.
Old 08-14-2006, 06:01 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
If it does turn out to be the GEM module, see if you can get the id number off it,and send me a line from my web page, look like I could sell it to you for around $250.00 but there are a few different ones listed so i need some info or id number.
Ed
Old 08-15-2006, 08:37 AM
Any input as to whether the GEM could cause all these issues? Thanks, Kevin
Old 08-15-2006, 11:49 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I just checked my 2001 service manual, and BOY OH BOY does everything go to the GEM.
What's worse is it looks like some of the inputs on the GEM are effecting what you are seeing. Sounds like it got wet.
HOWEVER, I'd check all the grounds going to the GEM. Sounds more like a bad connection, especially with the moisture effecting it. Definitely sounds like a bad ground.
Report back!
Old 08-15-2006, 01:40 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
chk the connection through the firewall ! In the past there have been some loose pins and water intrusion into the connector
Rich
Old 08-15-2006, 02:17 PM
Krewat's Avatar
Quote:
Rich
Spoil sport...
Old 12-20-2009, 09:43 PM
crackermantim crackermantim is offline
crackermantim is starting off with a positive reputation.
first my one touch windows quit along with my 4x4 lamp clicking on and off then my auto shut off for headlights would not work causing the battery to die before i had to go to work
anyways other than moisture what can cause this part to fail..like and bad connection to the window switch screw all these other items?
Old 02-11-2010, 10:25 PM
F 250 6 liter's Avatar
F 250 6 liter F 250 6 liter is offline
F 250 6 liter is starting off with a positive reputation.
Hello Looking for a GEM for 2003 F250. Do you sell them? Thanks
Old 02-12-2010, 12:50 PM
Former Vendor
Quote:
I do!
visit my web site www.partsguyed.com use the contact us link and send vin.
I'll send you a link to part so you can price/order
Old 02-15-2010, 11:30 PM
OK please send. I am told that Ford is on back order and they cannot get one?
Old 02-16-2010, 01:02 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
You can take the cover off the module for a visual inspection. Nice to see it first.
Old 02-20-2010, 06:41 AM
bterry's Avatar
bterry bterry is offline
bterry is starting off with a positive reputation.
100% identical problems in my truck. I'll bet your windshield is leaking and the water is running down the a-pillar under the trim and getting into your fuse box. First time I had taken it to the dealer to fix it, and I finally had to get a new fuse box.
The dealer just dried it all out somehow and it worked. Got my windshield replaced and all was good until it started happening again. This time I'm buying a new fuse box.
By the way, I'm confident your gem is just fine. When you take out the fuse box to replace it, you'll see that there's really no way for water to get in it, but the inside of your fuse box is green.
Old 02-20-2010, 06:43 AM
bterry's Avatar
Let me guess - your carpet is wet near the sill plate.
Old 04-10-2010, 03:22 PM
jclape jclape is offline
jclape is starting off with a positive reputation.
fuse box and gem
i hd both out the gem looks ok no corrosion any where but windows are not rolling down and occassional radio shut offs and when that happens windows work i here a clicking noise from fuse box when trying to roll down the windows i sprayed the conections to the fuse box with pb blaster and put it back in andit seemed to solve all of the otherissues like truck trying to start with no keys and all that should i replace the fuse box first and see if that solves the prob or what also the keyless entry box was filled with water and the door locks ony lock all the doors and unlock just the drivers door
Old 02-24-2014, 12:20 AM
JanneKinnunen JanneKinnunen is offline
JanneKinnunen is starting off with a positive reputation.
I have a question related to GEM module compatibility. I have a hard time on finding the exact match to replace mine:
7/20/99
F81B-14B205-DL
202057-114
FORD P131 GEM VERSION DL
Which other versions would work in my truck? It's 2000 F250 XLT Crew Cab, 8ft bed, 4x4 with 5.4L. My VIN is 1FTNW21L2YEA69523.
I took the GEM module out and circuit board looks fine. I cleaned up all the terminals and put the heater inside the truck. If the problems come back I will order a new/used GEM module.
Starter motor Powering itself...not relay RdaivdL 1999 to 2016 Super Duty 16 12-07-2016 09:02 AM
GEM module failure ? Jason Lilly Modular V10 (6.8l) 0 01-19-2016 11:02 AM
4WD Not Working Rusty Axlerod 6.0L Power Stroke Diesel 30 11-05-2015 05:29 PM
Tips for removing fuse block and GEM? WestCoastTodd 1999 to 2016 Super Duty 8 08-17-2015 03:54 PM
Help - H2O = no go! rflegal Excursion - King of SUVs 12 06-20-2015 12:55 PM
Tags
2001, 2002, 2003, duty, f150, ford, gem, modual, module, part, problem, problems, super, superduty, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
