04 F150 supercrew rear window leaks help!
Originally Posted by mucket
anyone have problems w/leaking window seal on rear window of 04 super crew F150?
Yep. Common problem on the 04's. There is a TSB out for this issue. The dealer will replace the entire cab brakelight assembly with a new design and gasket (for free). It's a good fix. Had it done to mine - no more problems.
CMOS
If the water appears at the top center of the window it is more than likely the light which is directly above. The water comes inside the cab between the inner and outer sheetmetal skins. When looking at it, it appears to be coming from the glass seal but it actually gets in behind the top edge of the light. The seal on mine had slipped inside the light. I used a small amount of silicone to fix it but now that I know there is a TSB I might have the dealer replace it.
<TABLE cellSpacing=0 cellPadding=3 width="96%" border=3><TBODY><TR><TD class=VERTCENT align=middle width="25%" bgColor=#ffffff>TSB
04-20-5
</TD><TD class=VERTCENT align=left width="65%" bgColor=#ffffff>
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>2004 F-150</TD></TR></TBODY></TABLE>
ISSUE:
Some 2004 F-150 vehicles may exhibit a water leak from the high mount stop lamp. The leak may be described as a water leak at the headliner, the back glass, wet seat covers and/or carpeting.
ACTION:
Verify water is entering through the high mount stop lamp assembly. Replace the high mount stop lamp assembly as needed. Refer to the following verification procedure.
SERVICE PROCEDURE
LEAK VERIFICATION
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>OPERATION</TH><TH align=middle>DESCRIPTION</TH><TH align=middle>TIME</TH></TR><TR><TD class=NOBOTTOMBORDER align=left>042005A</TD><TD class=NOBOTTOMBORDER align=left>Replace The High Mount Stop Lamp (Includes Time To Diagnose With The Climate Control Fan On High Non-Recirculating, And Soapy Water To Determine The High Mount Stop Lamp Is The Source Of The Leak)</TD><TD class=NOBOTTOMBORDER align=left>0.3 Hr.</TD></TR></TBODY></TABLE>
DEALER CODING
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH align=middle>BASIC PART NO.</TH><TH align=middle>CONDITION CODE</TH></TR><TR><TD class=NOBOTTOMBORDER align=middle>13A613</TD><TD class=NOBOTTOMBORDER align=middle>34</TD></TR></TBODY></TABLE>
Jus' in case the link isn't workin'...
04-20-5
- WATER LEAK FROM HIGH MOUNT STOP LAMP
ISSUE:
ACTION:
SERVICE PROCEDURE
LEAK VERIFICATION
- Turn the fan motor (climate control motor) on high, in the non-recirculating mode.
- Close all windows and doors.
- Spray a soapy water solution on the outside of the high mount lamp housing. If bubbles form around the lamp housing, replace the assembly.
WARRANTY STATUS:
DEALER CODING
