Replace split rims with new style rims ??
Old 06-08-2002, 06:29 AM
jethro1's Avatar
jethro1
jethro1 is offline
Old 06-15-2002, 06:39 PM
merkstang's Avatar
merkstang
merkstang is offline
I have 6 lug split rims on a F350 and I want to replace them with new style wheels so that I can use radial style tires - OR I would like to know how to convert over to 8 lug wheels. Is this as easy as changing the front spacers OR drums?
THANK-YOU in advance for your replies.
Old 06-15-2002, 11:28 PM
66camperspecial's Avatar
66camperspecial
66camperspecial is offline
Are you sure they are 6 lug ????? Only ones i have seen on F 250 and F 350 are 16 x 5 x 8 lug on 6.5 centers..I think anything 16 x 8 lug on 6.5 centers up to 1994 will fit 8 lug pattern on older F-250-350
Old 06-16-2002, 12:46 PM
merkstang's Avatar
merkstang
Yes I am sure that they are 6 lug dual wheels (dished out front rims)
I would like to use the 8 lug wheels is this as easy as changing the front spacers or would i have to change the drums too.
Old 06-20-2002, 10:22 AM
Charles-65F350's Avatar
Charles-65F350
Charles-65F350 is offline
Welcome to the world of "oddball" truck parts. I have the same problem on my '65 F-350 dually. There is NO simple way to put 8 lug rims on the front of your truck. Even Stockton Wheel can't or won't make them (their dually centers aren't offset enough or strong enough, or some such reason). I even asked if they could sell me their standard 8-lug dually rims but drilled on a 6-lug pattern but they apparently outsource these and can't special order a small quantity.
Extensive machine work on later model hubs would be required (seems like the bearing diameters and spacings are never the same). I took a pair 8-lug rims to the machine shop and had them weld six of the holes shut and then redrill on the six lug pattern. Not cheap but it works. I still carry a split rim with a tire/tube on it for a front spare, tossed in the bed. (The rear was easy, just swapped for a slightly later model Dana 70 with 8 lugs).
Of course it might be possible to put an F-Superduty solid front axle under your truck, with the disk brakes which would be a BIG help stopping these beasts. Not a bolt-in though, when I looked under an '80'something Superduty.
:-X23
Old 06-22-2002, 10:34 PM
merkstang's Avatar
merkstang
[updated:LAST EDITED ON 22-Jun-02 AT 11:35 PM (EST)]Thanks for the info I will try to get some stuff togther for the winter project. Is your truck finished --- well no truck is ever finished -- would you send me some pictures of what you have done? Tis may help me plan my project. I'm new to the Truck thing, Iam a Mustang guy. merkthom4100(No Email Addresses In Posts!)
Thanks for the input!!
Old 01-29-2021, 08:25 AM
77stepvan's Avatar
77stepvan
77stepvan is offline
[QUOTE=Charles-65F350;339662]Welcome to the world of "oddball" truck parts. I have the same problem on my '65 F-350 dually. There is NO simple way to put 8 lug rims on the front of your truck. Even Stockton Wheel can't or won't make them (their dually centers aren't offset enough or strong enough, or some such reason). I even asked if they could sell me their standard 8-lug dually rims but drilled on a 6-lug pattern but they apparently outsource these and can't special order a small quantity.
Old 01-29-2021, 08:42 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Necroposting - this is a 19 year old post. OP has not logged in since 2007.
Old 01-29-2021, 12:35 PM
robertrpeak's Avatar
robertrpeak
robertrpeak is offline
Necroposting
Damn ibuzzard, I had to look that word up...
Old 01-29-2021, 03:26 PM
ibuzzard's Avatar
ibuzzard
Originally Posted by robertrpeak
Necroposting
Think I learned it from my 7 year-old grandson - I ain’t that smart!
Mustangking1
Oklahoma Chapter
01-22-2014 09:27 PM
larryejoh
WTB - Parts & other
08-08-2011 04:19 PM
93 mix 'n match
WTB - Parts & other
03-02-2010 02:01 PM
jcab
11-20-2004 08:18 PM
frenchf250
Offroad & 4x4
28
03-02-2004 08:20 PM
Quick Reply: Replace split rims with new style rims ??
