1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Idle problems..Surges up and down?
Old 08-13-2006, 12:07 AM
t_money662's Avatar
t_money662
t_money662 is offline
Within the last couple of weeks, my 2001 Expedition (4.6L) has had some idle issues...
When I am in drive, and come to a stop, like at a red light, the engine seems to surge up and down. This doesn't happen when in park, only when in gear, and is starting to worry me.
What is this a symptom of?
thanks alot
Old 08-15-2006, 11:38 AM
gibsonj's Avatar
gibsonj
gibsonj is offline
Might be IAC. Check out this thread from the Explorer Forum:
https://www.ford-trucks.com/forums/1...pair-help.html
Old 08-16-2006, 12:29 PM
t_money662's Avatar
t_money662
Thanks, I will definately check the IAC valve with a multimeter for the proper resistances..
Old 08-16-2006, 01:34 PM
Mr.Novice's Avatar
Mr.Novice
Mr.Novice is offline
Also check out this recent thread:
https://www.ford-trucks.com/forums/5...-ac-is-on.html
I was reading in my Chilton manual last night how the IAC works with the A/C. Sounds more and more like an IAC.
Please let us know if/how you fix this problem.
Thanks!
Old 08-16-2006, 05:52 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
*F65Z9F715HA FTE 65.09
Let me know if you need one.
Ed
Old 08-18-2006, 03:00 PM
Thrower20's Avatar
Thrower20
Thrower20 is offline
I am having the same issues with my 98'. Could it be the TPS, I read the voltage and the closed position reads .05 higher than the top end of the range. Any ideas or should I be looking into the IAC also.
Rodney
120K, 5.4L, 3" w/ a 50 series Flowmaster, UNI Filter
Old 08-18-2006, 03:16 PM
Mr.Novice's Avatar
Mr.Novice
Rodney
Hi Rodney,
I happen to have a brand new TPS. I'm gonna throw it on this weekend and I'll let you know what happens.
If that doesn't fix it, I'll replace the IAC.
Old 08-19-2006, 12:45 AM
buzzard's Avatar
buzzard
buzzard is offline
If it's the IAC then you'll experience the symptoms in "park" as well, especially right at start-up...I'm betting on the TPS.
FWIW, mine surged in gear, like you mention, a couple times around 60K miles ago and hasn't done it since.
Old 08-19-2006, 01:20 PM
Mr.Novice's Avatar
Mr.Novice
Thumbs up Solution!!!
Buzzard, it won't necessarily do it in Park even though it does it in drive if it's the IAC that's going out.
I replaced IAC last night - Problem solved. I still have a brand new TPS if anybody needs one...
Old 08-21-2006, 02:03 PM
ghman's Avatar
ghman
ghman is offline
iac??
I have a '99 navigatior that won't idle. The computer gave a code of the mass air flow sensor so i changed that out and it still doesn't idle. where is the iac located on a navigator?
Old 08-21-2006, 02:58 PM
Mr.Novice's Avatar
Mr.Novice
Remove the "4.6" or "5.4" cover on your throttle body. On my 4.6, the IAC on the top-right side of the throttle body. I think it's on the opposite side on the 5.4's but don't quote me on that. It looks a lot like this (even though the link is for Explorers):
https://www.ford-trucks.com/article/...r_IAC_Fix.html
Old 08-22-2006, 05:55 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome ghman, to Ford Truck Enthusiasts!
See you on the boards. ….
jrgrtx
07-26-2017 05:06 PM
ftlover90
07-22-2017 01:04 AM
BuickBrian
Computer Chips & Tuners
06-30-2017 08:49 AM
acf6
12-23-2015 12:35 AM
fordboy97
11-12-2015 01:28 PM
Quick Reply: Idle problems..Surges up and down?
