speed density - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
speed density
Old 08-12-2006, 03:04 PM
kjg26 kjg26 is offline
kjg26 is starting off with a positive reputation.
speed density
i've been told some of the lightings ran a speed density system. i have an 89f150 4x4 with a 351w. i want to supercharge it. however from what i understand you have to do some things to "trick" the speed densityl system. anyone with any information on how to supercharge a 351W with a speed density system i would greatly appreciate it. thanks
keith
Old 08-12-2006, 11:55 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
You can use a boost/timing retard, FMU and boost activated inline fuel pump. These components will work with almost all of the factory kits available for your truck. The stock injectors will work fine as long as you keep the fuel pressure up. Larger injectors and some type of aftermarket tuning would be a better route to go with boost and speed density though.
Old 08-13-2006, 12:40 AM
any recomendations for which kit to go with?
Old 08-13-2006, 01:14 AM
Blurry94's Avatar
Vortech makes a kit for your rig.
Old 08-13-2006, 11:15 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Why not just get the kit from FRPP to convert it to MAF?
Old 08-13-2006, 01:24 PM
FRPP? sorry dunno what that is.
Old 08-14-2006, 12:01 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Ford Racing Performance Parts
Old 08-14-2006, 12:20 AM
Blurry94's Avatar
Ford does not (currently) make a conversion kit for a truck with an electronic trans.
Old 08-14-2006, 11:53 AM
i have a c6 trans. am i good? will this conversion kit work with my truck?
Old 08-14-2006, 03:33 PM
Roush_Shaun's Avatar
Roush_Shaun Roush_Shaun is offline
Roush_Shaun is starting off with a positive reputation.
As far as I know The only way you can modify a speed density system is to A) switch it to mass air or B) Buy a PMS unit that will pigtail in between your stock wire harness and your computer....and with this you can program your own settings. Option "B" from what I was told is better than converting to mass air.
Old 08-14-2006, 06:55 PM
Blurry94's Avatar
Quote:
Yes, convertering to mass air with that trans is much easier. If all you plan to do is run a blower and some bolt-ons, then it is possible to tune speed density to work with them.
SCT and Tweecer can also be used to tune it. If you plan to go that route, I'd recommend you invest in a wideband O2 (to monitor the air/fuel ratios) and a cab mounted fuel pressure and boost/vacuum gauge.
Old 08-16-2006, 10:04 PM
water 5's Avatar
water 5 water 5 is offline
water 5 is starting off with a positive reputation.
you think he may want to also take a look at the ease program for tunning you think?
Old 08-17-2006, 12:20 AM
Blurry94's Avatar
Quote:
Yes...me personally, I'd recommend it for anyone that wants to do their own tuning. I've been able to use EASE diagnostics to scan, and datalog, real time engine info to help me tune my farm truck...I've been quite pleased with it.
Old 08-17-2006, 03:18 PM
how easy is TwEECer to use? Can it be used on a stock truck?
Old 08-17-2006, 06:37 PM
Blurry94's Avatar
Yes, it is a little challenging for a beginner. I think many speed density equiped F-150's can use the same strategy as the GEN 1 Lightnings. You'd have to contact them to be sure though.
If you decide to do your own tuning, be patient and ask questions, and make sure you have all of the tools need to help dial in your combo; at the minimum I would suggest using a wideband and fuel pressure gauge.
Speed density Sixtone 1987 - 1996 F150 & Larger F-Series Trucks 11 03-19-2015 06:26 PM
Motor wiring harness question... Conaski?? 85camaroman 1987 - 1996 F150 & Larger F-Series Trucks 5 03-18-2015 09:19 PM
302 mustang supercharger on f150 rb2 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 4 07-06-2014 12:49 PM
302 build- speed density? rb2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 06-20-2014 04:46 PM
94 F150 302 to 351W swap Rupenthal94F150 Engine Swaps 2 01-16-2006 08:58 PM
Tags
351w, 58, bolt, density, ford, heads, jr, ons, speed, supercharge, trucks, tuning, victor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
