You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Getting ready to make a second batch of biodiesel. Did my titration and came up with 4 tenths of a milliter to reach a ph of 8. The test was the same last time I made a batch.I'm using peanut oil from local resturaunt that only cooks in it for three nights a week. Just wanted to see if anyone else has ever titrated oil this low. I would also like some input on mist washing .
I wouldn't think even pure veggie oil would titrate that low, but then again peanut oil is a higher quality.. I mist wash, Just lightly mist the first time then step it up with a bubbler on the second go around. After that I drop a heater in there for about 2 hrs or leave it in the sun. I let it sit afterwards for about 2 days just to make sure everything dropped out (soap and water) Also whats your base on titration? Your doing 5 as your base?
__________________
1997 f-250 cc 4x4. 37" toyo muds on 22's. Beans Stage 2 injectors. Ranch Hand front & rear bumpers and tool box. Tymar intake, TS 6 position chip, HPX and 5" stacks 17* HPOP. Head Studs. 7.3 Intercooler. Big Beans turbo. Rebuilt motor 1/18/2007
I'm using KOH so my base is 7. The guy I got my oil from said he was using the best peanut oil he could find,so maybe that is why it tested so low.He only cooks three nights a week four hours a night so its not used much. He changes the oil every week.
Standard formula if your not a tree hugger and trying to save every single penny you have is....25 gallons oil, 5 gallons methanol, and 3lb of Koh or if your still using sodium 2 lbs. Heat oil 150 and add the contents of methaloxide and mix for one hour. Drain to holding tank and wait.
__________________
585,000+ miles on original engine. Goldie 00 F-350
After all is said and done using this formula, how much fuel do you end up with?
Are you saying that formula can be used in lieu of the titration test?
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
Cookie that formula will work almost everytime, the titration test will allow you to usually drop the amount of KOH or lye that your using, thus saving money and usually reducing the amount of soap produced.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
If you get full conversion you should get about 98 percent of your WVO converted to Biodiesel.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Cool, thanks.
__________________
Scott
