wanting to buy
dang! i live in wagoner.
value all depends on condition. rust is a problem, but can be fixxed. a lot of parts are easy to find if you know what you are looking for. some are econo only, and can be hard to find and expensive when you do.
does it run and drive first. then how bad is the body second. [look for bondo in the nose around the headlights]. check the floors and around the rear panels for rust and bondo. windsheilds are avaiable if you look hard enough, and can run from 400-175 installed. rear glass can be cut to fit. 5 window corner glass is a used glass only. kinda scarce, but people do have them.
what engine and does or did it have? could be small six, or big six. 3 speed or automatic. tailgate any good, or at least rebuildable is a major plus! [gates are harder to find than hens teeth!]
tell me a little more about it and i will see if i can help you out!
mwarner1948
01-28-2014 08:55 PM
