Factory reprogramming 94 turbodiesel
Our OEM gages are not very accurate.
Does the gage move slowly up to the point that it usually reads or does it take more than 15-20 minutes to get there?
If it's slow, you will need a thermostsat.
You could Find someone with a scanner for the actual reading to the PCM (Powertrain Control Module) or a thermal (infared) temp reader and measure the temp @ the upper radiator hose too.
on
when i first got my 95 i thought i needed a thermostat too since my gauge didn't read quite right so i put a stat in it. no change! as cuda jim said stock guages are JUNK! get an aftermarket guage so when it does run warm you will know. i put one on mine and it has given me piece of mind my next one will be oil pressure as that guage is junk also.
also do as cuda said about double checking temp with a scan tool or infared thermometer.
