escort ignition wiring... - Ford Truck Enthusiasts Forums
Old 08-09-2006, 10:08 PM
nhswrld nhswrld is offline
nhswrld is starting off with a positive reputation.
so i have this 91 escort with the 1.8 dohc engine in it...the ignition lock switch is shot and a new one cost a pretty penny so i figured i could just hook up a switch and a push button .....the push button would be the starter and the switch would simple be the key in the "on" position, but i dont know what color wire is what...there is a six wire plug and also a two wire plug that go into the ignition lock switch....does anyone know which wire is which?
Old 08-11-2006, 09:28 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Here's something easier. If it's actually the lock that's shot, look at the bottom of the ignition switch assembly. There's a black plastic section that's held in with 1 scew and a clip. Remove it the screw and pull on the clip and slide it out, it's the actual electrical switch You can leave it hang and actuate it with a screwdriver till you can get another lock assembly. (Might try a wrecking yard to save some bucks.)
I went through this on my dad's old '91 Tracer (same car) but I just bought another switch and lock assembly complete from NAPA. I think it was about 60 bucks IIRC.
Old 08-12-2006, 08:44 AM
60 bucks aint bad, i actually rigged it for now....i popped the guts out of the ignition and "broke" the locks out inside then slide it back together...so i can pretty much start it with anything but it still looks like the normal key ignition
Old 08-12-2006, 11:21 AM
TigerDan's Avatar
That's even better. Nothing like having your ignition all busted up and taken apart, you ever get pulled over and the cop takes one look and assumes you stole the car!
I guess they're a troublesome part on those cars, my dad had problems twice with his. First it was the electrical switch portion, and then the lock itself.
Old 08-12-2006, 11:39 AM
tomw tomw is online now
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
If you have the patience of a saint, and the hands of a jeweller, you can fudge the old electrical switch apart, clean and lube the connectors, and re-assemble it. I had one where the switch down further on the collumn, moved by a metal rod, would make intermittent contacts... Not fun going down the road. Took it apart, cleaned and reassembled, and it was fine for years
tom
Old 08-15-2006, 12:19 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
ing switch F5CZ 11572-AA FACTORY OEM FTE$47.26 plus shipping, in stock!
Ed
1988 ignition wiring diagram lasthighboy 1987 - 1996 F150 & Larger F-Series Trucks 3 07-25-2014 05:13 AM
1988 ignition wiring lasthighboy Electrical Systems/Wiring 1 07-24-2014 06:54 AM
Ignition switch wiring diagram/color coding staysbroken 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-18-2010 10:05 AM
push button ignition? mitchw32 1987 - 1996 F150 & Larger F-Series Trucks 7 01-31-2005 09:21 PM
72 Ignition Switch Wiring mark78truck 1967 - 1972 F-100 & Larger F-Series Trucks 2 05-11-2003 09:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
11572, 91, aa, broke, escort, f450, f5cz, f5cz11572, f5cz11572aa, ford, ignition, key, start, switch, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
