waste veg oil - Ford Truck Enthusiasts Forums
waste veg oil
Old 08-09-2006, 07:48 PM
f350duallyguy f350duallyguy is offline
f350duallyguy is starting off with a positive reputation.
waste veg oil
can anyone tell me if I can add wvo (filtered of course) maybe a 50/50 mix with deisel,with no modifications.I have a 97 7.3psd
Old 08-09-2006, 07:55 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant futurebigredtruckmi has a brilliant future
Filter it to 10 Micron to get thru your fuel filter. You could run B100 during summer but winter i would cut way back unless you heat it.
Old 08-09-2006, 08:20 PM
winter isn't a problem,i live in central Florida,if it gets blow 40 it doesn't stay there long
I hate to sound like an idiot but,you're saying filter it and pour it right in the tank,as long as i add it to existing fuel,it will run finr and won't hurt any thing...fuel lines, hoses,pump..ect.
Old 08-09-2006, 08:21 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
You are rolling the dice and the life of your truck is at stake.
Why not do the mods and run straight WVO or not do the mods and run Bio.
Either way is 100 times less risky than mixing VO and diesel.
Old 08-09-2006, 08:31 PM
IABill's Avatar
IABill IABill is offline
IABill is gaining momentum as a positive member of FTE.
Talking
Look around here more & you will re think that. In a nut shell wvo will not stay mixed with petro diesel. un-heated straight WVO will cause all kinds of problems. If you have a Constant supply of WVO Look at Lesk WVO converson kits or Bio-D processor, Appelseed, Biodieselsolutions ect. I have the bio-dsolutions unit a bit pricey still gona take about 800 gallons to pay for its self but no more money to the bad guys...
Old 08-09-2006, 08:37 PM
thanks for the info,I'll look into the mods,getting the oil is no problem,need to do something this 90.00 fill up every 8-10 days is killing me
Tags
67, f250, ford, forum, grand, ledge, mi, veg, vegoil, waste, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
