2.3 turbo check engine light wire color - Ford Truck Enthusiasts Forums
Old 08-09-2006, 04:42 PM
nhswrld nhswrld is offline
nhswrld is starting off with a positive reputation.
hey guys, ive got a 2.3 turbo out of a 88 turbo coupe, i need to hook up the check engine light, but i do not know which wires run to the check engine light and/or which port they come out of the computer at....
Old 08-11-2006, 08:46 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Take a look at this pic of the EEC test connector:
The terminal marked "Self-Test OUT" should be what you want. Hook into that wire at the back of the plug and run it to your CEL.
I was looking for a diagram in my books to see what terminal of the computer is used for the CEL but I couldn't find the right diagram for your engine. You might want to order an EVTM (Electrical and Vacuum Trouble-shooting Manual) from Helm Publications:
http://www.helminc.com/helm/welcome_...V21CLWQ4E65F77
I bought one of each for my Ranger and for the Mustang I got the 5.0 out of. Very useful for figuring out where each of the wires need to go when doing a swap.
VGT cycling 2004 PS 6.0/turbo whine/TSB 09-24-3 Andrewdavis34 6.0L Power Stroke Diesel 12 04-13-2013 09:16 AM
300ci to a 2.3 turbo on a 2wd f150 blackinkforge Engine Swaps 1 03-25-2008 06:21 AM
2.3 performance modifications? Great Parts 4 Cylinder Engines 3 01-28-2005 08:57 AM
2.3 turbo t bird swap deltaranger 4 Cylinder Engines 9 08-16-2004 01:10 AM
2.3L to 2.3l turbo FrdRanger01 Engine Swaps 4 07-30-2004 06:03 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1987, 2003, 23, check, color, coupe, engine, f150, ford, hook, injector, light, turbo, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
