06 F250 horn location - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-09-2006, 10:27 AM
tlamshooter tlamshooter is offline
tlamshooter is starting off with a positive reputation.
O.K. guys, I searched the threads about adding horns, but I just had to buy a big truck electic horn to replace existing. My problem is that I can't find the existing horn to rewire into my replacement. Any help would be appreciated. Guess I should have popped the hood before buying the horns. Thanks.
Old 08-09-2006, 11:04 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Quote:
you have to remove the inner fenderwell liner to get to them,if memory isn't failing me its the passenger side
Rich
Old 08-09-2006, 11:10 AM
Bear Hunter's Avatar
Bear Hunter Bear Hunter is offline
Bear Hunter is gaining momentum as a positive member of FTE.Bear Hunter is gaining momentum as a positive member of FTE.
You can tap into the factory horn wire behind the fuse box. Use a multimeter to check the wire. On an 04 it is "Yellow with Green Tracer"
If I were you I would put a SPDT mini toggle under your steering column that will allow you to switch between your factory horn and your new electric ones. The position of the switch will determine which horn is sounded when you push the horn button in your steering wheel.
http://www.truckblog.com/story-792-h..._and_air_horns
Old 08-09-2006, 12:32 PM
pistolpete837's Avatar
pistolpete837 pistolpete837 is offline
pistolpete837 is starting off with a positive reputation.
hey tlamshooter
which horn did you buy? i am interested in doing the same thing.
Old 08-09-2006, 01:00 PM
Thanks guys. I will have to look at which is easier, I think going into the fuse box might be easier and more room to mount the horns on that side. Like I said, I should have looked before I leapt since my F250 is brand new (bought it last month) I didn't worry about modifying my 96 F150 that I sold to buy the 250. Pistol Pete, I bought the twin horns on this link. But my new truck doesn't have as much room as I had thought for mounting them.
http://www.wolo-mfg.com/elec.htm
Old 08-09-2006, 05:24 PM
i think i have the same horn on my bronco and im not to impressed with it but hopefully you will have a better experience.
Old 08-09-2006, 08:40 PM
Cobra97Vert Cobra97Vert is offline
Cobra97Vert is starting off with a positive reputation.
here is the one I just bought. Bolts in place of factory and reuses the same wires and mounting, thats why I chose this one. Just got it in, havent had time to install yet.
http://www.stylinconcepts.com/parts..../categoryid/31
horn pad Problem Cowboy34 1973 - 1979 F-100 & Larger F-Series Trucks 12 02-10-2007 04:53 PM
Adding louder horn but keeping original for alarm? caadoptees 1999 to 2016 Super Duty 7 06-06-2006 05:06 PM
98 Explorer horn oskie Explorer, Sport Trac, Mountaineer & Aviator 4 01-27-2006 01:38 AM
Horn location?? Fire Rooster 1999 - 2003 7.3L Power Stroke Diesel 13 08-24-2004 02:03 PM
Was a horn an option in 1970? lee 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-30-2000 01:57 AM
Tags
2000, 2002, 2004, 2005, duty, f250, factory, ford, horn, location, remove, removing, replacement, super, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
