blower switch replacement - Ford Truck Enthusiasts Forums
Old 08-08-2006, 06:20 PM
puck1263 puck1263 is offline
puck1263 is starting off with a positive reputation.
How easy is it to replace the A/C blower switch? Ford only has the unit as a whole to replace, but parts stores have the individual switch. Can only the switch be replaced?
Old 08-09-2006, 05:38 AM
mississauga mississauga is offline
mississauga is starting off with a positive reputation.
I have never replaced it, but looking at my spare from an 88 there are 2 screws holding it on the the assembly. The blower motor switch is also attatched to the same assembly. To get at it , the trim piece has 4 clips holding it on which is a matter of carefully pulling off. Underneath there is 4 screws holding the assembly in place. Once removed you can disconnect the electrical harness ,vaccum hose connector and slide wire and the whole thing can come out. I think the hard part is getting to the switch but that isnt really that tough.
Old 08-09-2006, 02:59 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Quote:
What year is it and why need replaced? Just wondered my fan would only work on high went to get replacement . Parts man said it was a sensor beside blower in engine compartment. Easy fix . But I think the one I took out of my 93 is all one peice but didn't look that close. If I can find it I'll see. Good luck.
__________________________________
94 Ford XLT 4x4 super cab long bed MAF 302 at
Old 08-09-2006, 08:38 PM
Got-r-done and back to proper operation. Parts store had one in stock. 4 easy clips, 4 easy screws, one screw on the switch, properly pulled **** off, unplugged from harness. Install reverse.
Looks like it got pretty hot. The switch was black and the harness was melted.
Old 08-09-2006, 08:45 PM
Glad you got it fixed. Sounds like it is the blower motor switch that was the problem.
Blower Switch on my 2003 Excursion mribbich Excursion - King of SUVs 13 05-19-2016 01:22 PM
Front blower run only on full speed dessmo Excursion - King of SUVs 2 02-14-2016 11:01 AM
Temperature Control Switch to the blower Ford 1984 zerocoolsob 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 11-30-2014 10:08 AM
Blower motor not working in 2009 e350 MikeBlansfield 1968-2013 Full Size Vans 7 10-16-2014 06:02 AM
Blower intermittently works fixit5561 Cooling, Heating, Ventilation & A/C 1 07-27-2010 01:59 PM
Tags
blower, fan, ford, heater, repair, replace, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
