Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-07-2006, 08:06 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CUSS
1989 Ford Ranger
Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation
Check your refrigerator and water heater gas pipe!
Every once in a while it pays to open up the side panel behind your reefer (the one on the outside of your motor home or camper) and check to make sure no bugs have made homes in the mechanism. The flue pipe may also get rusty, and you want to make sure you have a nice clean blue flame right where it ought to be.
The same is true of water heaters...
In fact MORE so. There is a gas/air mixing tube that is prone to becoming infested with critters that think it's a nifty place to build a nest. It doesn't bother much if only a pilot light is on, but when the main gas flow comes through - if it is blocked - the propane can divert around the tube, fill the compartment until it reaches the pilot flame, and BWOOOOSH!!!
You can expect to find your access cover about twenty feet away...
I also wanted to mention that you should never ever operate the water heater if there is no water in it. For one thing - if it is hooked up to park power, the electric heating element will burn up. The system can only read water temperature if there is water inside. QED: No water, no temperature reading - it will keep on running, thus using up all of your LPG, and/or destroying a perfectly good heating element.
Consider this my initial tip of the day....
~Wolfie
__________________
2009 FTE Online CHAMPIONSHIP
FINAL ROUND of COMPETITION
  #2 (permalink)
Old 08-09-2006, 12:55 AM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of jake00 has much to be proud of
great post, might be stickie material
__________________
06 F250 CC v10 4x4 Lariat
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #3 (permalink)
Old 08-09-2006, 12:13 PM
CmprSpecial's Avatar
CmprSpecial CmprSpecial is offline
CmprSpecial is gaining momentum as a positive member of FTE.
To add to this if the fridge doesn't work well on gas (or at all for that matter), check for rust on the burner. I have had 2 friends who had the same fridge issue. A peice of rust from the flue fell down and covered the burner. It covered enough of the burner to keep it from heating correctly, but not enough to keep the sensor from telling the system the flame wasn't on. Very strange, but true...
__________________
Enjoy,
Bill
'73 F-350 Trailer Special
Replaced by:
'04 F-250 XLT V-10 4X4 ,3.73 LS, LB, Sport Package, 6820 lbs empty, all stock so far
  #4 (permalink)
Old 08-09-2006, 10:02 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
On reefers - beware of the igniter wire too. It doubles as a thermocouple to the controller board, but the main thing is it carries enough volts to lift you right out of your socks!
If the reefer is running in "AUTO" mode, and it doesn't sense 115V from a hookup - it will try to light the LP burner. Make sure it is turned off before reaching around inside the compartment.
It's also a good idea to make sure your LPG valve is on before running the fridge. (DOH!)
Refrigerators don't use much gas. The flame is only about as tall as a butane lighter flame, and it would take a month of sundays to use up a 7.4 gallon propane tank. THIS is a good way to save amperes for other things such as your A/C, especially with a thirty amp RV connection.
You always have to figure - if there are only thirty amps coming in, you need to budget those amps for whatever you run.
A 15,000 BTU A/C unit will pull close to 20 amps initially, and then drop to about 16.
__________________
  #5 (permalink)
Old 09-08-2006, 09:00 PM
Canuk Canuk is offline
Canuk is starting off with a positive reputation.
Thats the way I set up. I use LPG setting for the fridge and hot water. Something like a toaster or hair dryer will draw a lot to. Using the gas settings usually gives you more reserve power for other appliances or tools. I have used my air on low with only 15 amp hookups set up this way.
  #6 (permalink)
Old 09-08-2006, 09:54 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
Right on!
Keep on RV-ing!
They are what they are, because of what is learned on the road....
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
