Interesting Item Ford FE girdle
Check out ebay listing 260016534108. It's a bracket that fits the bottom of an fe and provides additional support to the main bearing caps. I'm no expert but I'd call this something like the poor man's cross bolt. I bet it does help but it's probably not nearly as good as a cross bolted block. Someone else with more knowledge please weigh in on this. I'd like to hear what everyone thinks.
Tracy
Tracy
After some more thought on it I think it looks pretty good too. I don't think I could use the FT pan in the truck though. I had to shim the engine up slightly to use it as it is because of the windage tray and the depth of the FT pan. I believe that the bottom end would be just as strong if not stronger than the FE blocks with the extra webbing. This is just another thing to add to the list for my next FE build. It's only money....LOL.
Tracy
Tracy
What does it cost to take a standard block and have it cross bolted? If you can do that for a similar price or not much more then I would agree that is the way to go. I don't have enough experience to know myself. I do think this girdle looks like a pretty simple modification that would give a whole lot of support to the bottom end.
Tracy
Tracy
KC sells girdles, they claim they work very well and use them on some of their engines. Like mentioned it's an option besides cross bolting and they mention that in the girdle description. If you want to check out KC's take on a girdle, it's on their "Our Engines" page at the bottom left of the page.
I think it's a good option and I was going to use one myself. There's no way it can't help (makes sense really). They mention that the 390/428 blocks split in excess of 600HP, and these will help improve the numbers.
Madmike33
Madmike33
The one thing that I would think might make this a bit useless is the slop in the holes, especially around the pan rail. How tight does it fit? If there is slop, then it's going to walk around and then not do a thing.
When cross bolting a block there is ZERO clearance and it's basically solid after torquing the side bolts. When installing this, you torque the main caps, then install the pan and tighten. That's swell, but that doesn't seem like much support. I might be splitting hairs, but I'd rather have true cross bolts. They recommend line honing anyway, so I'd rather spend the $500 to have real caps put on(well, I can do my own machining, but anyone else).
Originally Posted by rusty70f100
Personally, I'd run a D3TE truck block with the extra main webbing and stronger iron to begin with if I was going to make that kind of HP. Last one I got, I paid $35... Cross-bolt that and I think you'd have something!
Madmike33
Originally Posted by FalconStng
Hmmmm....Down here in Houston I can't find such an animal. I'm looking for a block to build right now. I'd really like to acquire a decent 428. Anyone know where to get one for a reasonable price?
Of course the girdle is still a good idea! I dont mean to .
try Ray Hillenbrant on www.fordfe.com he has had several 428 blocks and shortblocks for sale. prices are very reasonable too! These are industrial engines but are true CJ blocks with the "C" on the back, IUB cranks, stock slugs and big bolt C7-B CJ rods. He posts in the classifieds there so take a look. He had some bare blocks for sale also. if you do check out the truck blocks bring a 13/64" and 17/64" drill bit with ya to gap the wallcores. 13/64" is a snug fit for 428 wallcores. 17/64" fits 390 wallcores....
G.
