Fuse Box Diagram - Ford Truck Enthusiasts Forums
Fuse Box Diagram
Old 08-07-2006, 11:47 AM
Yakima5019 Yakima5019 is offline
Yakima5019 is starting off with a positive reputation.
Fuse Box Diagram
Looking for a fuse box diagram for my 1976 F150. I can see the box, but all the wording on the fuse box has faded off. Thanks.
Old 08-07-2006, 01:53 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Bottom left. Dome Light ,Cigar Lighter,courtesy glove box & Cargo light 15 amp
Bottom right Hazard lights & stop lights 20 amp
From top down - Haater & Defortser or AC - 30 amp
2nd one down - BU lights,TS & WS washer - 14 amp
3rd one down - *Lighting* Instrument Panel,Cluster , Ash Tray,Trans indicator,Radio,Heater/AC,ATC ,Headlamp,WW switch lamp.
Old 10-09-2006, 12:41 PM
cowboyty cowboyty is offline
cowboyty is starting off with a positive reputation.
How about a diagram for a 1978 F250 fuse panel? Is it the same?
Old 10-09-2006, 02:30 PM
loveoldtrux loveoldtrux is offline
loveoldtrux is starting off with a positive reputation.
yakima5019 --------
What's wrong with the fusebox - are your fuse terminals corroded and falling apart like mine are? I'm currently working on having to replace mine... I took the fusebox off of the firewall yesterday..... it's real easy.... I don't think it's going to be too much of a pain to repair the water corrosion damage on the fusebox (water dripping in cowl)....
Old 10-11-2006, 01:45 AM
Cowboy,
Old 10-11-2006, 06:56 AM
Thanks Mil1ion!
Old 10-11-2006, 08:51 PM
OLDBLUE'77f-250 OLDBLUE'77f-250 is offline
OLDBLUE'77f-250 is starting off with a positive reputation.
what year is the digram above for. I have a 77 and the lettering is rubbed off.
Old 10-11-2006, 09:13 PM
brentleedragon's Avatar
brentleedragon brentleedragon is offline
brentleedragon is starting off with a positive reputation.
it is for all years i believe
Old 10-11-2006, 09:38 PM
the diagram is the correct look for my fuse block but on mine the #9 spot (turn signal flasher) is blank or somone has taken the concetors out. My turn signals work....so there has to be some kida difference.
Old 10-11-2006, 09:48 PM
mine worked without the fuse
but do not recomend it lol
go get a 15 amp the right size ive actually had trouble getting the right size fuses
from napa but i think Ford supplys kits
Old 10-11-2006, 11:26 PM
i would put a fuse in the #9 spot but there are no connectors?!?
Old 10-12-2006, 12:38 AM
That fuse box is 76 and newer.
I don't know the deal on the #9 spot.
I know I have an empty spot on mine but can't remember which one it is right now.
I think #5 is empty but,
I'll check tomorrow.
Old 10-12-2006, 08:48 AM
my #6 (dual tank) is also empty
Old 10-12-2006, 04:41 PM
It appears my #1 is the only one blank.
1995 Ford F250 351 4WD Under Hood Fuse Box Diagram andrewcollins2 1987 - 1996 F150 & Larger F-Series Trucks 15 08-28-2016 08:21 PM
Under dash fuse box diagram Rick Henry Ranger & B-Series 2 03-09-2016 06:00 PM
Does anyone have a fuse box diagram? Classicerror 2004 - 2008 F150 4 10-17-2009 01:31 PM
1976 F-250 Fuse Box RangerYamahaGirl 1967 - 1972 F-100 & Larger F-Series Trucks 1 09-30-2006 07:31 AM
Looking for a diagram of the Fuse Box Layout for '92 3.0 V-6 Aerostar Walking_Tall_0403 Aerostar 8 11-04-2003 10:34 PM
Tags
1976, 77, diagram, f100, ford, fuse, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
