In Need Of Bracket for power steering/AC on 7.3 - Ford Truck Enthusiasts Forums
Old 08-07-2006, 10:35 AM
kyle01041981 kyle01041981 is offline
kyle01041981 is starting off with a positive reputation.
I have a 1993 F250 4x4 with a 7.3L. I need the mounting bracket for the power steering pump, AC , etc. The Tension pulley hole on the cuurent one is stripped out. Any help in find a reasonably priced one would be greatly appreciated.
Old 08-07-2006, 08:30 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
There were several revisions of the front accessory mounting in 93. You may need to find a part number to match up.
For a cheap yet durable fix, have you thought about heli coiling the hole? I can't remember if the threads are cut in the aluminum or if there is a steel insert.
Jason
Old 08-08-2006, 09:18 AM
Ok thanks for the info, Ill try to get a part #.
Yeah I thought about heli coiling but didnt think that would fix it since a heli coil works best if there is something behind it. I was afraid it would push out of the bracket since the hole is open on both ends......Any thoughts on this...It sure would save me alot of money if it would work....I am just a little skepticle of heli coil since the hole is in the bracket and not in the block.
Old 08-08-2006, 09:21 PM
RCrawler's Avatar
The design of the helicoil causes them to expand when installed so it won't move around. If it is installed correctly, you shouldn't have a problem.
Jason
Diesel fuel hose leaking kyle6241 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-22-2015 08:22 AM
power steering pump bracket abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 03-23-2015 11:23 AM
Will this power steering bracket fit? Ripcity 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-26-2013 06:01 PM
WTB: 460 Ford Van power steering pump bracket w/ AC F3fitty WTB - Parts & other 16 11-19-2011 12:25 AM
help adding power steering to a 300 with factory ac 136045 Ford Inline Six, 200, 250, 4.9L / 300 5 09-08-2011 09:35 PM
Tags
1993, 73, ac, bracket, f250, ford, mounting, power, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
