460 Aod?? - Ford Truck Enthusiasts Forums
460 Aod??
Old 08-06-2006, 09:11 PM
1ford1 1ford1 is offline
1ford1 is starting off with a positive reputation.
460 Aod??
I am wanting to put a 4spd auto in place of my C6. I have a 460 in a 1978 F100 (2wd). I want it to be as painless as possible. I have a large number of salvage yards to get used trannies from. I am not sure what 4spd autos came behind the 460. I dont want to mess with the wiring for any electronics. Did the AOD come with the 460? I have to do a rebuild on my C6 anyway and would rather put a 4spd auto in. I realize I will have to deal with the driveshaft and am planning on ordering a higher stall speed converter as well.
Old 08-07-2006, 09:19 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
Quote:
You're out of luck. The E4OD was the only four speed auto ever bolted to the 460. It requires electronics to work.
If you really want an AOD, you'll need an adaptor. The AOD was never bolted to the 460. And then you'll need an expensive rebuild, because a 460 will tear up a stock AOD VERY quickly.
Old 08-07-2006, 11:17 AM
Thanks for the reply. Do you know if there is a wiring kit available to make the EAOD work?
Old 08-07-2006, 12:55 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
Here's the web page for Baumann, they have what you need.
http://www.becontrols.com/
Old 08-07-2006, 07:38 PM
RTM RTM is offline
RTM is starting off with a positive reputation.
It's referd to as E4OD not EAOD. The E4 trans does not have a very good reputation. In 94 or I think it was that year ford upgraded the E4 trans. Most rebuilds are done with the upgrades. A good rebuild will run you well over $2K. I have seen many post where people advise that one install a remote trans filter which will help provide a longer life to E4 trans. I have added remote filters to the tow trucks at the shop. Figured it can't hurt.
If you don't mind a manual trans then the ZF would be the cheapest way to go but you will have to modify you clutch pedal for a hyd set up.
Old 08-07-2006, 08:11 PM
Thanks, I had heard the E4OD was as strong as the C6. I am not planning on spending $2k on this. I will run one of my C6's. I was hoping to get the overdrive for my occassional trips to Tampa. The savings in fuel would not justify a $2k upgrade. Has anyone heard much about the TCI Streetfighter C6's?
Transmission 78f-350 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-22-2014 09:25 AM
76 highboy 390 428 460? Bigjl 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-17-2012 01:53 PM
Putting a AOD behind a EFI460 vee10td Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 08-15-2011 10:34 AM
460 flywheel problem johncart 1967 - 1972 F-100 & Larger F-Series Trucks 40 09-29-2008 12:05 AM
C6 to AOD Swap witdog2020 Clutch, Transmission, Differential, Axle & Transfer Case 5 01-09-2006 07:47 AM
Tags
460, aod, bbf, bolting, c6, converter, craigslist, driveshaft, eaod, ford, kit, rebuild, stall, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
