Max. oil temperature? - Page 2 - Ford Truck Enthusiasts Forums
Old 08-10-2006, 10:37 AM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
That's kind of what I was thinking. If that was the case, these modular motors with 5w20 should be taking themselves apart left and right, no?
Old 08-10-2006, 02:27 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
Smile
Quote:
Originally Posted by seventyseven250
Jim, so are you saying that modern engines have a design flaw the requires aftermarket products to fix?
I'm not saying anything. Just passing along information. This is a quote from the referenced web site. I checked a couple other sites, Gale Banks Engineering being one of them. The say approximately the same thing. Draw your own conclusions. jd
Old 08-10-2006, 02:56 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Quote:
I disagree, you are saying something, that's why you put that post there. I have to assume that those sources you reference have their own reasons for the information that they post, possibly selling more aftermarket products. Let's face it, if they told you that your engine didn't need their stuff, you wouldn't buy it.
The ideal operating range for engine oil is 180F through 200F.
Below the boiling point of water? I'm surprised.
Oil that exceeds 220F rapidly loses its ability to lubricate and cool causing accerlerated fatigue and premature component failure.
Cooler oil will certainly cool the engine better, and it may even be beneficial for other reasons. However, I'm willing to bet that the Engineers of these modern engines designed them to run at a certain temperature for a reason.
This may not be applicable to race engines that have their oil changed ever few hours of use, or in other specialty applications. I'm only referring to normal use in a modern stock vehicle.
Of course, now I'm just being argumentative.
Old 08-10-2006, 07:49 PM
Smile
I haven't been on this board very long. It seems to me to be very difficult to post something without getting some kind of glib, superfulous answer from someone. Crap gets old. If you don't know what I meant, you are dumber than dirt. You implied that my statement was my thoughts, which they were not, which I thought I explained.
Maybe what you say about the products is true, pure advertising hype, I don't know, and really don't care. Gale Banks orginization is a very reputable firm, and until I learn otherwise, I will take his information as correct. The man asked a question, I gave him information, and sourced it. He can make up his own mind.
On the other hand, I haven't seen anything from you, or anyone else disputing the figures, or substantuating your own. These figures have been around for years, and are nothing new.
The figures are for a stock engine, racing temps run much higher. jd
Old 08-10-2006, 11:24 PM
I wasn't trying to be glib, if I came across that way, I apologise. You are also correct that I haven't brought forward any references. I'll just restate my two main points and then anyone reading can draw their own conclusions.
- Water does get into oil under normal operation, and boiling it out at temps over 212F is an effective way to remove it.
- Modern engines are designed to operate using modern oils at temperatures between 220 and 295F (according to jimdandy, which I don't despute.)
At least this has been a good discussion that should help people think about oil temps and other related issues.
getting hot while towing jstoddard 6.0L Power Stroke Diesel 12 09-15-2016 09:03 PM
Oil cooler delete Waterlogged 6.0L Power Stroke Diesel 5 08-30-2016 10:14 PM
Trans temperature Bigblockboy Clutch, Transmission, Differential, Axle & Transfer Case 4 04-22-2016 10:05 PM
Oil and Water delta - wrench light - P012F code ontarioford 6.0L Power Stroke Diesel 20 05-25-2015 06:38 AM
Controlling temperature on an air cooled diesel parkland General Automotive Discussion 10 06-13-2014 02:04 PM
Tags
240, 460, degrees, engine, f150, ford, high, hot, ideal, max, motor, oil, temp, tempature, temperature, temperatures
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
