Any ideas on what causes this? All air is blowing through the defrost regardless of what setting. Everything else is okay. AC, Heat all work fine. Just this issue of all air going through defrost.
what is the best way to look for the leak? Isnt the hose between the battery and the firewall? Interesting or just coincidence that it all started right after I replaced the battery and cleaned the corosion from the battery cables. I know just coincidence.
Thanks. I can see what I believe I see the line you refer to. I bet I knocked it off when putting the cover back on. Unfortunately, I don't see where it connects. any help is appreciated it. The line itself is only about 8 to 10 inches long.
where can I get a diagram that shows me. Its obvious I have a thin hose lose. there is actually two. the one that is loose is coming off a connection that has a blue circle piece on it. Does the other end go into the connection in the white resevoir?
that blue circle piece is a check vavle. from there it should go to the resevoir and from there to the source for inside, but dont quote me on that not 100% sure. you should be able to get a chiltons manual for the diagram
