Flash Evaporation - Ford Truck Enthusiasts Forums
Flash Evaporation
Old 08-05-2006, 10:43 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Lightbulb Flash Evaporation
Ok guys, something else new to try! This should work for WVO or Bio. On one of the "other" boards I belong to we've been discussing the use of "flash-evaporation" to remove water from the WVO prior to making Biodiesel.
The basic system consists of a 2" pipe with a "tee" at the bottom with a waterheater eliment in the lower hole and the oil comming in the side if the "tee"
with the 24" pipe comming out the top. At the top of the pipe is another "tee" mounted with a thermometer in one side of the tee and a fixed "orifice" mounted in the other. A gear pump is used to supply the oil to the bottom of the collum at 150 psi.
The way it works is by heating the oil to 300-350 deg under 150 psi. This keeps the water liquid when it would normally boil off at no pressure. When the oil "sprays" out the orifice the water turns to steam and is removed off the top of the container and the dewatered oil falls to the bottom. Works great to dewater oil before putting it into your processer.
What I'm going to try, is to use it to remove the methanol from Biodiesel.
I have found that by removing the Methanol from the Biodiesel the soap will come out of suspension and can be removed by filtering.
I've read several studies that show the soap will come out of suspension because it will not stay in the bio without the methanol there. This is why letting it stand for 30 days will drop out the "slime" [soap].
Will post more after I've built one and done some experimenting.
FABMANDELUX.
Old 08-07-2006, 08:46 PM
furball69's Avatar
furball69 furball69 is offline
furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.furball69 has a very good reputation on FTE.
FABMANDELUX.
I read a post somewhere on this board in the last few days, that a fella use a bit of lard with the oil and the lard makes everything drop out of suspension very quickly... Actually, I just tried searching to locate the post and can't find it, so maybe it was somewhere else.
Old 08-07-2006, 09:28 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Fab
my concern is that suspended soap particles might plug the orfice. I don't know that would happen but keep an eye on it for saftey sake.
Old 08-07-2006, 10:45 PM
Quote:
Originally Posted by Phydeaux88
Fab
My fault, I should have said the oil has to be prefiltered. The experiments I've done so far show that the soap is a gel and the orfice is not that small anyway.
The soap seems to "cling" to the sides of the tank, and settle to the bottom.
Since I don't water wash, but use settling, I've noticed that there is a "whiteish" "crud" that seemed to cling to the sides of my main settling tank. Normally I just dumped it into my "slime" tank and used it for heating. I tested some of it this weekend and found it was almost pure soap!
I'm going to try using my hydrocyclone to remove the soap before it goes to the flash evaporator.
FABMANDELUX.
Old 08-14-2006, 04:54 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
You know you wont have but a few minutes to spend on that, with that carshow, other boards, Idaho, Texas calling, Universities calling, portable units to make, boat to restore, barn raising and barn burning ect.........Couldnt resist because resistance is futile. Ha ha ha dont ask me to bring you anything back from Maui, its all made in China.
Old 08-14-2006, 05:58 AM
Quote:
Be nice now...........or I won't reveal all the secrets I'm bringing back from my trip to ISU Tuesday
FABMANDELUX.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
