code p1780 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
code p1780
Old 08-04-2006, 10:59 AM
biged52 biged52 is offline
biged52 is starting off with a positive reputation.
code p1780
does anyone know what might cause this code. thanks
Old 08-04-2006, 11:16 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
What year is the truck, and which engine?
P1780 - Transmission Control Switch Out of Self-Test Range
During KOER self-test the TCS has to be cycled, if not cycled a DTC is set.
Possible causes:
l TCS circuit short or open
l Damaged TCS switch
l Damaged PCM
Old 08-04-2006, 11:23 AM
sorry its a 1999 3.0
Old 08-04-2006, 11:37 AM
Rockledge's Avatar
The Transmission Control Switch is the button at the end of the shift lever on the steering column.
Old 08-04-2006, 03:44 PM
thank you so much
Code reader KCMAGERS 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-08-2007 01:36 AM
Codes 172, 176 WXboy Ranger & B-Series 5 11-06-2002 09:13 AM
Code Reader Codes & Problems Quantrex Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-02-2002 07:53 PM
Engine Codes Ford Inline Six, 200, 250, 4.9L / 300 2 05-03-2002 02:31 AM
CODE SCANNER Pastmaster 1987 - 1996 F150 & Larger F-Series Trucks 7 05-01-2002 08:05 PM
Tags
2003, 2004, 42, 98, circuit, code, dtc, engine, explorer, ford, p1780, range, tcs, test, transmission, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
