Transfer case will not engage front drive shaft
I have a 1988 F-250 7.5L auto with a borg 1356 transfer case. When I shift into either 4H or 4L the front drive shaft does not engage. The transfer case was rebuilt 2 years ago and only has 2000km on it.
When I leave the hubs unlocked and shift into either 4H or 4L and have someone watch the drive shaft when I move forward or reverse the drive shaft does not spin. So... to confirm this I then shift into 2H and lock the hubs and voila, the shaft spins.
So there is no problem with the hubs, it's the transfer case that does not engage the front drive shaft, therefore no 4wd. Other than the front drive shaft not engaging the transfer case appears to shift fine. When I'm in low range the drive drives in low range, just no 4wd.
This truck is new to me with almost every component having been replaced over the past few years, in really good shape. I even have the invoice from the tranny shop that did the rebuild, but they will not help since it's been two years.
Does anybody have any ideas what could cause this??
curioduo
08-06-2015 09:22 PM
jfj
09-05-2002 01:51 AM
