4 Months Back I changed plugs then miss
I put autolight plugs in my 97 f150 4.2 160,000 miles. then It started to miss jerk at about 50 -60 up a grade or slight aceleration. I figured I broke a plug wire so replaced them at that time. The threads were saying to by ford plugs so I bought them but did't put them in. Yesterday truck was hard to start, and then was soft off idle. I checked my scaner p0102 low maf.. Replaced maf and now runs perfect again was the maf all the time not the plugs ; symtoms the same though. the code just came on but I suspect was weak all along . Why it hapened when I changed the plugs is freeky or I must have jared the maf when I changed the air filter. Many posts here on the plugs but the same complaint on other site say the maf - hope this helps $189.00 at ford for the part.
