Check engine and OD light flashes at same time
Could be any one of dozens of things. You need to get the codes read.
Go to AutoZone or wherever, have the codes read. WRITE DOWN the actual code numbers (DTC)(not the descriptions). Do not let the drone at the store attempt to diagnose the fault or sell you any parts since most do not have the needed skilles or experience.
Come back here and look for prior discussions by clicking on SEARCH and using the DTC as your SEARCH keyword. If you need anything expanded upon or additional information, just ask.
Steve
Steve
