zoodad mod?? how to ??
Old 08-02-2006, 08:21 PM
mjlevi's Avatar
mjlevi
mjlevi is offline
Can someone point me in the right direction to get the instructions for doing the zoodad mod, I can not seem to find it anywhere, and is doing this suitable for the stock air intake?? and explain what the benefits are !! thanks
Old 08-02-2006, 10:32 PM
NavyPowerstroker's Avatar
NavyPowerstroker
NavyPowerstroker is offline
Yes it is suitable for the stock intake. Basically making sort of a ram air intake. Basically the intake tube is blocked by the radiator support. So if you take the grill off the truck (screws on top, 4 clips on bottom) then right in front of the intake tube use about a 4" hole saw or something similar and cut a hole. I then used a dremmel tool to clean it up to make it look like it came from the factory like that. Hope this helps.
Old 08-02-2006, 10:43 PM
LAWNMOWER MAN's Avatar
LAWNMOWER MAN
LAWNMOWER MAN is offline
Did It Help Navy? I Have A Afe Stage 2 Sith Other Mods Do You Think The Zoodad Will Help ?
Old 08-02-2006, 11:12 PM
NavyPowerstroker
It is pretty noticeable at highway speeds. That is where this mod really shines. I don't have an aftermarket intake but I would think this would really work well with it.
Old 08-03-2006, 08:38 AM
barnbridge's Avatar
barnbridge
barnbridge is offline
I drilled my Zoodad hole slightly lower than the intake opening, hopefully it will help keep rain out of the air filter yet still allow an easier path for the air.
Old 08-03-2006, 09:18 AM
kw5413's Avatar
kw5413
kw5413 is offline
OK guys, the ZooDad mod pics and instructions are scattered throughout the 6.0 forum. This need to be consolidated and put into one single post.
I need someone to write up the complete instructions, with pictures if possible, and I will link it through the 6.0 Tech Folder.
Any takers?
Old 08-03-2006, 11:49 PM
LAWNMOWER MAN
thanks navy i think i might just have to try the mod alwayslooking for new things to add and play with my truck
Old 08-13-2006, 12:02 AM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
Here is a link from an old post of some pics someone posted on the internet.
Linking to it in the tech folder would be good...
http://community.webshots.com/album/29503747CLxEtpIVYO
Old 08-13-2006, 12:20 AM
JORYLEE76's Avatar
JORYLEE76
JORYLEE76 is offline
Those are some great pics of the zoodad mod. My truck is completly stock to but i think i may do this sometime down the road.. i have to do all of the "major" work on base at the "hobby shop" do to the fact that i live in an appt. complexe.. oh well right.. ok thanks again and ya this should get into the tech folder. keep it up you guys rock.
JoryLee
Old 03-10-2009, 08:27 PM
CoastieMK's Avatar
CoastieMK
CoastieMK is offline
I'm gonna do this mod this weekend or sooner if work is slow. Has anyone put any sort of a screen or cap over the hole to keep bugs and critters out after they did this? I'm just thinking if it makes sense to do it or would it get sucked into the intake?
Old 03-10-2009, 08:39 PM
bismic's Avatar
bismic
bismic is offline
Received 2,449 Likes on 1,696 Posts
When I did mine, I bought a "Predator Air Fury" grill. Can't recall where I bought it from. The grill is pictured in the link below. I will try to find where I bought the grill by itself.
TruckXpressions.com - Predator Air Fury
Y2KW57
22
08-26-2020 10:35 AM
dakotajeep
04-17-2017 10:49 PM
Blue7.3
Australia Chapter
12-25-2015 11:20 PM
mjlevi
03-22-2013 12:55 PM
WJC
08-01-2009 09:33 AM
Quick Reply: zoodad mod?? how to ??
