Remote starter problems - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 08-02-2006, 10:53 AM
SShank42's Avatar
SShank42 SShank42 is offline
SShank42 is starting off with a positive reputation.
I have a 2001 V6 4x4. The factory installed Ford remote start will not start the vehichle most of the time. It will however go thru it routine. The lights flash, the horn blows, the blower motor comes on, the radio comes on, and the dash lights come every time just like they should. It does everything it should except for starting. Found one relay and replaced it but still the same thing. Every great now and then it will start but not very often. Thanks.
Old 08-10-2006, 08:43 PM
crazyrwe's Avatar
crazyrwe crazyrwe is offline
crazyrwe is starting off with a positive reputation.
Did you buy this new,I never heard of a factory installed remote start.I've seen remotes that say Ford on them,but an aftermarket company installed them.
Old 08-11-2006, 08:40 AM
SShank42's Avatar
Ford installed before we took delivery. It was done at the dealer. The reason I know this is because when we went to pick it up it was not done. It was in pieces in their shop waiting for something from Ford to finish the install. I think it was a relay they were waiting for. They forgot to tell Ford the vehichle had an alarm or theft deterent (whatever you want to call it) on it.
Old 08-11-2006, 12:53 PM
crazyrwe's Avatar
sounds like a starter wire they conncted from the ignition.Do you have any problems starting it without the remote?
Old 08-11-2006, 01:57 PM
SShank42's Avatar
Starts fine with the ignition switch. Everything is perfect. Just will not start from the remote.
Old 08-11-2006, 02:02 PM
crazyrwe's Avatar
just a silly question,are your batteries fresh?
Old 08-11-2006, 02:32 PM
SShank42's Avatar
Yes they are.
Old 08-11-2006, 02:45 PM
crazyrwe's Avatar
If you can find out where they grounded it,I would check there.If thats ok,you may want to get the test light out and start checking if you have power all the time from the ignition wire to the starter,they had to tap off of that somewhere.
Old 09-03-2006, 08:10 AM
tekrsq tekrsq is offline
tekrsq is starting off with a positive reputation.
Did you ever get this fixed?
I had a "factory installed" remote start on my 03 Ranger. After about 6 months it started doing the exact thing yours is doing. After 5 trips to the dealer to get it fixed, I took it to a car stereo shop and had them look at it. Come to find out my "factory installed" remote start is actually a DEI system the dealer put in, AND they didn't solder any of the connections when they put it in. There is a wire that connects to the vehicle starting circuit to engage the starter. This wire was just twisted onto the starter wire, and wrapped in electrical tape. Over time it had just come loose. Talk about pissed off when I found out what kind of job the dealer had done!!! Anyway, the stereo shop went through the system and soldered all the connections. Haven't had any problems since !!!!
Old 09-06-2006, 09:08 AM
SShank42's Avatar
I have not fixed it. Looking at the connections was the first thing I did.
Old 09-06-2006, 09:27 AM
tommyleea tommyleea is offline
tommyleea is starting off with a positive reputation.
Quote:
If Ford installed it then I would go back to Ford and have them fix it. Next, I would find out who actually manufactured the unit. Most of the companies have very good tech support. I installed one on the wifes car, and after about a month it would start, but immediately shut down. Ended up to be a wire that had to be bypassed. Working fine for 3 years now. Good Luck....
Old 09-20-2010, 10:11 PM
STGERMAIN STGERMAIN is offline
STGERMAIN is starting off with a positive reputation.
REMOTE START
I JUST PICKED UP MY F150 YESTERDAY. REMOTE START WORKS, BUT WHEN I OPEN THE DOOR THE TRUCK DIES!!! ANYONE KNOW HOW I CAN FIX THIS? IT IS FACTORY INSTALLED... I FOUND THE BOX, JUST NOT SURE WHAT TO CHANGE... ANY HELP???
THANKS
J
Old 09-21-2010, 11:03 AM
Buck 1 Buck 1 is offline
Buck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to behold
STGERMAIN: No problem. Mine did the same thing, altho my '08 had one installed that worked when the door was opened. With the new " MyKey " technology, the remote starts are installed and set to shut the engine off when the driver's door opens. Took mine back to the dealer, the guy who installed it came over, pulled off the access door at the driver's end of the dash. Took him all of 20 seconds to program the remote start NOT to shut the engine off when the driver's door opens. Just take it back to the dealer and have it re-programmed.
Old 09-21-2010, 05:14 PM
BUCK 1: THANKS, I WILL DO THAT...
remote starter issues ClayC 2004 - 2008 F150 3 01-09-2017 05:24 PM
Remote Start + heaters Lastwagen 6.7L Power Stroke Diesel 20 01-04-2016 11:57 AM
Help - stuck with family, vehicle won't start becuase factory remote start fob is broken kcolg Electrical Systems/Wiring 3 03-11-2015 11:08 PM
Ford PowerCode Remote Start not working Buck 1 2004 - 2008 F150 11 01-21-2014 08:19 PM
2010 F-150 FX4 Remote Start Problems Slonner 2009 - 2014 F150 4 01-21-2012 12:56 PM
Tags
2003, 42, alarm, automatic, error, escape, f150, ford, problem, problems, remote, start, starter, support, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
