Powder Coating - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Powder Coating
Old 08-02-2006, 07:07 AM
1ole4d's Avatar
1ole4d 1ole4d is offline
1ole4d is starting off with a positive reputation.
Powder Coating
Does anyone know of a place between Lumberton and Monroe that does powder coating? I want to get the frame, front and rear axles done. I decided against stripping and paint them myself. Way too time consuming. I just don't have the time to attack it all with a ginder and a couple of cans of paint and primer.
Old 08-02-2006, 07:14 AM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
to paint a frame you really need to use a sand blaster. instead of a gridder but i don't of anyone that powder coats frames. you can try the charlotte area that would be the first city in NC that i would check, but i have heard it is very expensive.
Old 08-02-2006, 07:55 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Question
Old 08-02-2006, 09:06 AM
primer85f150 primer85f150 is offline
primer85f150 is starting off with a positive reputation.
pinehurst blacksmith shop, murdocksville road does powder coating . its about 3 miles fromthe hospital.
Old 08-02-2006, 11:53 AM
1ole4d's Avatar
Quote:
Do you know the name of the place or a phone number?
Hey, if you're not busy sometime you ough to come by and check out the F-150, or what's left of it right now. It would be nice to be able to start meeting some of the local Ford Fans.
Old 08-02-2006, 12:54 PM
1-910-295-6905 pinehurst blacksmith shop is the name, and they have a websit my # is 206-6299
Old 08-05-2006, 02:54 PM
did you get up with them? just checking in, primer
powder coated frames 460harris 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-20-2016 11:20 PM
Question about powder coating abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-08-2016 08:55 PM
wheel paint baker1983 1994.5 - 1997 7.3L Power Stroke Diesel 4 05-29-2012 07:15 PM
Powder coating vs painting of the frame southernboy0122 1987 - 1996 F150 & Larger F-Series Trucks 11 03-23-2011 07:30 PM
Powder Coat Hammy321 Michigan Chapter 4 11-15-2009 08:32 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
