dual fuel tank wiring - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 08-02-2006, 06:41 AM
wally2117 wally2117 is offline
wally2117 is starting off with a positive reputation.
I have a 86 E350 cutaway with dual tank and the front gage is reading Empty regardless of the fuel level in the tank.
I'm looking to troubleshoot the problem but the wiring colors in the Haynes are not the same as on the truck.
I found another diagram and the colors aren't the same too.
I would like to test my wiring before dropping the tank and can't find the right colors to test the fuel sender.
The wiring from the front tank has a green, brown and couple of black wires.
Also the fuel selenoid valve has 5 wires (red, green, green, brown, orange)
I can't find these colors on any diagrams.
Thanks for your help.
Old 08-02-2006, 06:57 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
What engine do you have?
Is this an RV?
Is it FI?
This one matches your colors:
http://i54.photobucket.com/albums/g91/subford/Fuel/1987FuelpumpselE1505.gif
Old 08-02-2006, 10:53 AM
It's a Motorhome with a 460 carburated.
I looked at the drawing you posted and I think you have the right one!
I'll check this afternoon with my meter to spot my trouble.
Thanks a lot.
Old 08-02-2006, 12:51 PM
subford's Avatar
You more than likely can use that diagram for wire colors to check out your gauges but I think that one is for a FI Van.
Here is one that I would think would be wired the way yours is but the wire colors are wrong for your year. This one is for 1983 and 1984 460 carbureted with the hot vapor bypass.
http://i54.photobucket.com/albums/g91/subford/Fuel/1983FuelElCT.gif
Old 08-03-2006, 10:26 AM
Thanks but I already had this one.
The first you sent has the exact colors for the switch and the selenoid valve.
I ran my tests yesterday and the results with the connector at the selenoid unplugged were:
rear tank - full - sender reads about 18 ohms.
front tank - empty - sender reads about 70 ohms
I also received at the plug, the pulsed 5V.
I went to the gas station and fill the front tank and took another reading on the front sender. That time it reads open circuit. The gage is still marking empty.
I'm now almost certain that the problem is on or in the tank. I will have to drop it.
Old 08-03-2006, 12:02 PM
subford's Avatar
Quote:
I drew that one for a guy with a 1983 F250 but other than the wire colors it should be wired like yours.
The senders should read:
73 ohms Empty
22 ohms half a Tank
10 ohms Full Tank
Open wire (disconnected) from the gauge the gauge will read the same as it does with the Ignition Switch off, Below Empty.
Grounding the wire from the gauge the gauge will read more than full.
Old 08-04-2006, 07:06 AM
Thank you SubFord. and others.
As I wrote above, my tests ran on the senders told me that the gauge itself works OK but the sender in the front tank is not responding. Its reading is good for the empty position but when the tank is full, sender doesn't give the good resistor value.
1988 E250 dual tank fuel problem dhuddleson 1968-2013 Full Size Vans 8 10-30-2015 07:29 PM
Need stereo wiring help - 1995 Ford F700 thaugen Large Truck 1 07-31-2012 10:23 AM
1986 F250 460 Engine - Fuel Wiring Diagram Cerran 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 05-10-2011 11:43 PM
dual fuel tank gage wally2117 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 08-04-2006 06:16 PM
E350 dual tank problem woodysfj40 Fuel Injection, Carburetion & Fuel System 1 05-21-2003 02:22 PM
Tags
1983, 1994, 1996, dual, e350, f150, ford, fuel, orange, sender, switch, tank, tanks, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
