b100 help
Old 08-01-2006, 07:03 PM
DNewton's Avatar
DNewton
DNewton is offline
b100 help
when and if i get a 6.9, hopefully in the next few weeks, i plan on running it on straight biodiesel, ive heard that in order to do it, some parts need to be replaced, what do i have to get/replace in order to run the biodiesel? all help is appreciated, Dustin
could someone mabey make me a list, and mabey a ballpark price for it all?
Old 08-01-2006, 08:58 PM
IABill's Avatar
IABill
IABill is offline
Wink
Dustin Here we go again! from what I have read natural rubber lines should be replaced with something newer I think vitron or something like that. Your 6.9 will LOVE Bio-D I have been brewing for about three months my PSD and IDI run fine on it I have yet to have to change a fuel filter(most folks advise bio will clean the fuel system and send all of the old garbage right to the filter) but have spares onboard both units. PSD runs a bit Quieter I think..... On the IDI I can't tell. The Bio has MUCH higher lubricity than current petro fuel and when the ULSD hits all over the country you will need to use an additive to keep the pump from wearing itself out. I used stanadyne performance formula @ 8oz per every tank B-4 Bio but that stuff is pretty high priced Power service & Howes & others out there will fill the void until you get into the Bio-D as far a list all rubber fuel & return lines is where I would start Sorry I have no clue on cost....Hang out though sombody here most likley has "been there done that"....Good luck.......Bill
Old 08-01-2006, 11:48 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
Hey Bill up late? You will not need any addative for the ULSD if you use any bio. The manufactures are going to put bio in it anyway in order to keep the millions of 18 wheelers and pickup on the road without seizing up engines....now for your 6.9
I just was discussing that today with good ol dad and this is what he said.
The injection pump should be rebuild and upgraded. The cost on this a few years ago when he wrenched on diesels was 100 cost. Now you will have to let you fingers do the walking to call around for pump rebuilding shops. The fuel lines are the other concern if not metal. I think regular fuel line will sufice for a while but im not sure yet.
Old 08-02-2006, 04:31 AM
DNewton's Avatar
DNewton
DNewton is offline
i see, thanks guys, so i should invest in some "vitron" fuel lines? and thats a definate on the IP rebuild?
Old 08-02-2006, 12:31 PM
IABill's Avatar
IABill
IABill is offline
Talking
Yep I was up a bit late hehehe.... good deal on the Bio in the ulsd I just figured I would need to keep a little stanadyne around for when I run low on bio & have to buy fuel....
Old 08-02-2006, 01:49 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
If you fill up with #2 before you run out of Bio you shouldn't need Stanadyne. All you need is about 5% Bio to get lubricity up.
Old 08-02-2006, 02:05 PM
kennedyford
That is why the prices will be jacked up when the new 07 fuel and trucks are out, they figure we are too stupid to know that should reduce the price...YES on the Injectory Pump.
hunter444
19
09-06-2014 11:36 PM
turboman24
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-13-2007 10:15 AM
gastank727
11-29-2006 10:28 AM
redstroker
25
08-31-2006 02:54 PM
FLASH 13
16
07-06-2006 12:46 PM
Quick Reply: b100 help
