Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-01-2006, 07:03 PM
DNewton DNewton is offline
Garage is empty, add now
DNewton is starting off with a positive reputation.
b100 help
when and if i get a 6.9, hopefully in the next few weeks, i plan on running it on straight biodiesel, ive heard that in order to do it, some parts need to be replaced, what do i have to get/replace in order to run the biodiesel? all help is appreciated, Dustin
could someone mabey make me a list, and mabey a ballpark price for it all?
__________________
Dustin
1991 F350 7.5l CC LB 4 inch lift
  #2 (permalink)
Old 08-01-2006, 08:58 PM
IABill's Avatar
IABill IABill is offline
IABill is gaining momentum as a positive member of FTE.
Wink
Dustin Here we go again! from what I have read natural rubber lines should be replaced with something newer I think vitron or something like that. Your 6.9 will LOVE Bio-D I have been brewing for about three months my PSD and IDI run fine on it I have yet to have to change a fuel filter(most folks advise bio will clean the fuel system and send all of the old garbage right to the filter) but have spares onboard both units. PSD runs a bit Quieter I think..... On the IDI I can't tell. The Bio has MUCH higher lubricity than current petro fuel and when the ULSD hits all over the country you will need to use an additive to keep the pump from wearing itself out. I used stanadyne performance formula @ 8oz per every tank B-4 Bio but that stuff is pretty high priced Power service & Howes & others out there will fill the void until you get into the Bio-D as far a list all rubber fuel & return lines is where I would start Sorry I have no clue on cost....Hang out though sombody here most likley has "been there done that"....Good luck.......Bill
__________________
Light travels faster than sound.
That's why some people appear bright until you hear them speak.
2007 F-350 Lariat CC,LB,SRW,2x4, Brite Box, High Idle sw, No Kitty & Straight Pipe, Blue spring & Sinister coolant filter & Fumoto.
  #3 (permalink)
Old 08-01-2006, 11:48 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Hey Bill up late? You will not need any addative for the ULSD if you use any bio. The manufactures are going to put bio in it anyway in order to keep the millions of 18 wheelers and pickup on the road without seizing up engines....now for your 6.9
I just was discussing that today with good ol dad and this is what he said.
The injection pump should be rebuild and upgraded. The cost on this a few years ago when he wrenched on diesels was 100 cost. Now you will have to let you fingers do the walking to call around for pump rebuilding shops. The fuel lines are the other concern if not metal. I think regular fuel line will sufice for a while but im not sure yet.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #4 (permalink)
Old 08-02-2006, 04:31 AM
i see, thanks guys, so i should invest in some "vitron" fuel lines? and thats a definate on the IP rebuild?
__________________
Dustin
  #5 (permalink)
Old 08-02-2006, 12:31 PM
IABill's Avatar
Talking
Yep I was up a bit late hehehe.... good deal on the Bio in the ulsd I just figured I would need to keep a little stanadyne around for when I run low on bio & have to buy fuel....
__________________
  #6 (permalink)
Old 08-02-2006, 01:49 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If you fill up with #2 before you run out of Bio you shouldn't need Stanadyne. All you need is about 5% Bio to get lubricity up.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 08-02-2006, 02:05 PM
That is why the prices will be jacked up when the new 07 fuel and trucks are out, they figure we are too stupid to know that should reduce the price...YES on the Injectory Pump.
__________________
Tags
b100, ford, void
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
