Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 10-23-2006, 11:14 PM
exposition exposition is offline
exposition is starting off with a positive reputation.
OOps'forgot to give my E-Mail mch2510@kingwoodcable.net
  #62 (permalink)
Old 10-24-2006, 08:45 AM
MattsExcursion MattsExcursion is offline
MattsExcursion is starting off with a positive reputation.
exposition- I will send that out
  #63 (permalink)
Old 10-24-2006, 09:15 AM
Keypad code.
Thank You . I appreciate your effort & expertise in solving this puzzle .
Exposition .
  #64 (permalink)
Old 10-24-2006, 04:37 PM
scitzo_frenic scitzo_frenic is offline
scitzo_frenic is starting off with a positive reputation.
Easy code find
I have an 03 excursion and after reading the posts I went looking for the code for my door. I removed the 2 screws holding the trash bag hook plate in place and the module with the code was sitting there in plain view.
  #65 (permalink)
Old 10-24-2006, 11:52 PM
I have a 2000 Excursion, and it is not there!
  #66 (permalink)
Old 10-24-2006, 11:53 PM
exposition- no problem at all! glad to help!
  #67 (permalink)
Old 10-25-2006, 12:37 AM
twobear twobear is offline
twobear is starting off with a positive reputation.
Another humble request for the code macro. Thanks. ted_w_olds@yahoo.com
  #68 (permalink)
Old 10-25-2006, 08:39 AM
twobear- I sent that out to you! good luck!
- matt
  #69 (permalink)
Old 10-27-2006, 03:07 AM
housedad housedad is offline
OK, OK, so I'm a
housedad is gaining momentum as a positive member of FTE.
I have checked with my Ford Repair manual DVD's and have found that the module is called 2 different things depending on what year Excursion you have. I also found that the module is located in 2 different places. If anyone uses this, finds the keypad codes on the 200-2001 module, please do a photo write up of it and submit it as an article!!!
In the 2000-2001, it is called the Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) and is located behind the fuse panel. You have to dismantle the fuse panel to get to it.
2001 -02 instructions From the Ford DVD's:
The GEM controls a variety of systems:
  • 4-wheel drive functions
  • front and rear interval wiper/washer
  • warning chimes
  • keyless entry
  • interior and exterior lamps
  • power windows
  1. Remove the instrument panel steering column cover.
    1. Unlock the retainers.
  2. Remove the instrument panel steering column cover.
3. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
  1. Loosen the bolts.
4. Disconnect the bulkhead connectors.
5. Position the instrument panel fuse junction panel aside.
  1. Remove the nuts.
  1. Remove the bolts.
  1. Remove the generic electronic module/central timer module (GEM/CTM).
    1. Disconnect the electrical connectors.
    1. Remove the screws.
    1. Remove the GEM/CTM.
  1. To install, reverse the removal procedure.
In 2002 and up, it is located behind the radio in the center of the dash and it is called the Vehicle Security Module (VCM).
The VSM controls the following systems:
remote keyless entry (including panic feature)
computer-operated locks
autolamp
keypad keyless entry (Excursion only)
__________________
2005 EXCURSION!! XLT V10 Silver Heated trailer mirrors. Added Hood/window deflector, Firestone airbags/onboard air, Helwig swaybar, Prodigy, underhood liner and light, V's and Modded B's, Bilsteins, Procomp stabilizer, Landyot genIV, Curt front reciever, 4.30 axles, C-Betr mirrors, Factory fogs, door lights, 3 gauges, ashtray(no hook).
  #70 (permalink)
Old 10-29-2006, 08:43 PM
hayklye hayklye is offline
hayklye is starting off with a positive reputation.
Smile Thank You for the help!
I have a 2003 Eddie Bauer EX and my door code was not in my paper work and the Ford dealershipship wanted the truck for sveral hours and an unknown price to get me my code. Everyone that has posted here helped me to find mine and the keypad now works! I took the trash bag holder out then the drink cup holder. I then looked to the left and was able to find the code! It was rather hard but like you guys said a good flashlight and alittle searching has me now being able to use the keypad. Thank everyone!
  #71 (permalink)
Old 10-30-2006, 08:05 AM
rush2112 rush2112 is offline
rush2112 is starting off with a positive reputation.
Matt,
Can you send me the codes at krumm_c@bellsouth.net? Thanks.
  #72 (permalink)
Old 10-30-2006, 09:43 AM
Rush2112,
I sent you those codes... good luck!
-matt
  #73 (permalink)
Old 11-01-2006, 12:12 PM
BIG BOI's Avatar
BIG BOI BIG BOI is offline
BIG BOI is starting off with a positive reputation.
matt if possible, could i also get a copy of that document sent to me, i'm tired of trying to find the code,
jomarjosh@hotmail.com
  #74 (permalink)
Old 11-01-2006, 03:27 PM
Big boi,
I sent them out!
good luck!
-matt
  #75 (permalink)
Old 11-01-2006, 04:22 PM
jrpoland jrpoland is offline
jrpoland is starting off with a positive reputation.
I found my code written (by the previous owner) right there in the owner's manual....it might save you some work to check any paper documentation you have--maybe you'll get lucky like I did!
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
