Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- How to Reprogram Door Keypad Code
Step by step instructions for do-it-yourself repairs
Keyless Keypad Code
#706
#707
#709
From Keyless entry and keypad code update? - Ford Powerstroke Diesel Forum
On a pre-2002 you have one 20 minute option..
The De Bruijn sequence!! It's 3125 numbers that WILL unlock your door..
Once it's unlocked backtrack 5-10 numbers and start from there until you figure out
what 5 digits did it.. Not fun, but you can do it quicker then going to the dealer.
Here's the link to the number and info you need to do this!
Weak security in our daily lives - Everything2.com
#712
If for some reason the code is more than 5 digits then no. Also, once you get the code in and unlocking, the process to change the code may be different (consult the owners manual).
If you are referring to the stickers, not sure if they'd be in similar locations or not (my gut says not).
#713
When I purchased my current Ex, I went to ford for an oil change and asked for the code. They gave it to me without charging the normal $99. You could try that
#714
#715
#716
Code for 2006 F250 - behind drivers side storage bin
Just purchased a new to me, used 2006 F250, read tons here, took off a lot of panels, and ended up with a sore back. Searched YouTube and finally found the code behind the drivers side storage bin. Had to look way back there, by moving the white foam/insulation out of the way. Got it! Programmed it! And it worked!
See this super helpful video:
Very easy....once you know where to look.
#717
#719
See this super helpful video: https://www.youtube.com/watch?v=tZ4V_vfm-6M
#720
Is there a way to enable a brute force lockout on the older models? I KNOW my code. I'd like to somehow make it so that someone can't come up and enter the 3000 number combination to open the door.
Also, is there a way to change the master code? I know you can add an additional "personal" code, but the master code still stays in there.
