Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #466 (permalink)
Old 06-21-2009, 12:14 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
They can be anywhere under there but I don't think the 00 and 01 had them anywhere.
  #467 (permalink)
Old 06-24-2009, 02:43 PM
tdappleman tdappleman is offline
tdappleman is gaining momentum as a positive member of FTE.
Thought I'd post my results.... I looked everywhere - even took the radio out and could not find the box. Turns out it was hidden behind some white insulation - and a fairly large bundle of wires. It was almost directly behind the 4wd switch panel on the firewall. I could look straight up while laying on the floor and with a mirror and flashlight read the front label. Factory code is now written in the manual and a personal code set! The best part is I was able to disable that auto lock!
__________________
2003 Excursion EB 4x4 V10, MT ATZ 285/75-16, Hawk LTS pads front & rear with new rotors
2000 Explorer XLT 4x4 - 30k miles
1974 Bronco 4x4 - 302, 3spd, 3.54 LSD front and rear - Restored beach toy
www.coastalfastlube.com
  #468 (permalink)
Old 07-26-2009, 11:14 AM
Ken ex Ken ex is offline
Ken ex is starting off with a positive reputation.
Quote:
Originally Posted by burgf250 View Post
Mattsexcursion:
I have a 2001 X with the same problem. I sure would appreciate it if you could email the codes and any instructions on how to do this. This would great to not have to pay the dealer to find the code.
Email address is pato2004@comcast.net Thanks.
Rick
I have a 2005 X with the same problem. I sure would appreciate it if you could email the codes and any instructions on how to do this. This would great to not have to pay the dealer to find the code.
Email address is kenandfaye@gmail.com. I would be so gratful. thanks
  #469 (permalink)
Old 07-26-2009, 11:22 AM
  #470 (permalink)
Old 07-26-2009, 01:02 PM
EXv10's Avatar
I posted them a while back. Use the advanced search to find them.
  #471 (permalink)
Old 07-26-2009, 01:07 PM
TWIZLR TWIZLR is offline
TWIZLR is starting off with a positive reputation.
I have a 2004 and found the code on behind the radio. It was a pain to read, but I got it and worked perfectly.
  #472 (permalink)
Old 07-27-2009, 01:32 AM
EXv10's Avatar
Your 03' is about the time they started putting them under the dash so you might not find it. Just use the code and you will be in in less than 20 minutes.
  #473 (permalink)
Old 08-04-2009, 10:36 PM
michael102105 michael102105 is offline
michael102105 is starting off with a positive reputation.
I have a 2000 ex to cant find the code under the dash it would be great vettdvr if you could pass on a copy to me to please mqreynolds@hotmail.com
  #474 (permalink)
Old 08-05-2009, 02:50 AM
EXv10's Avatar
Quote:
Read my posts above.
  #475 (permalink)
Old 09-29-2009, 03:32 PM
carsound2001 carsound2001 is offline
carsound2001 is starting off with a positive reputation.
Quote:
Originally Posted by MattsExcursion View Post
I have a 2000 X, and when I bought it, the owner had no idea of the code. So I looked at article after article... tore apart the WHOLE dash, and looked in all the places... NO CODE... I guess they didn't put printed codes on the '99 SuperDuty and 2000 X.. I wasn't about to pay $100 for some guy to tell me the code, so I looked into it more. I read a forum (not sure where) where someone used Microsoft Word to create a Macro to make all the possible codes... (sounds like something you wouldn't want to do, but you will be surprised) There are 5 buttons on the keypad. So you go into word create this macro that uses all the possible 5 digits numbers it could make with 0 1 2 3 4. It makes about a total of 10 sheets of codes at like 5 or so columns on each page.... TONS OF CODES. You then label the 1/2 key: 0 the 3/4 key: 1 and so on.... so now your keypad looks like 0 1 2 3 4... then you enter codes.... I did this for 10 min. and found my code. Some may be quicker, some may take longer... If anyone would like me to send them this word document with all the numbers, I would be glad too, also if anyone would like me to explain the procedure better I will. I'm so greatful that I found out about this way. I wish I would have remembered who it was so I could give the credit to that person, but it was probably 6 or 8 months ago. Good Luck!
i have a 2000 v10 excursion and i have looked all over under the dash and can not find any box with a number on it,there is a box behind the radio up under the metal support of the dash but cant see any number, if sumone can email me the process of trying different number in sequence that would be great,thanks
  #476 (permalink)
Old 09-29-2009, 03:33 PM
my email is rrmccaffery@aol.com sorry forgot to put it on the posting for the key code thanks
  #477 (permalink)
Old 09-29-2009, 05:08 PM
mdgilles mdgilles is offline
mdgilles is starting off with a positive reputation.
Door codes
I have the copy saved, check you email
  #478 (permalink)
Old 09-29-2009, 05:15 PM
abmorejon abmorejon is offline
abmorejon is starting off with a positive reputation.
keyless entry code number
I found my code on my f250 behind the radio area. I took off the coin or storage box and had to move some insulation and cables to see it, but found it on a white box.
  #479 (permalink)
Old 10-02-2009, 06:28 PM
dlr71's Avatar
dlr71 dlr71 is offline
dlr71 has a good reputation on FTE. dlr71 has a good reputation on FTE.
Quote:
Having trouble finding the code myself, i was told that for that year if was in the rear compartment behind one of the doors, I have not found it yet. Please let me know if you find it, I have the same year excursion. Good Luck.....dlr71
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
__________________
David, DE Charter Member, Sussex County
2000 Excursion
1998 Eddie Bauer Explorer 4X4
1982 F-100
  #480 (permalink)
Old 10-02-2009, 06:43 PM
EXv10's Avatar
It's not on the 00 and 01. Use the hack method in here and you will be in in 15 minutes. I guess you didn't read my post above.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
