Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #451 (permalink)
Old 05-10-2009, 12:06 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by lynsta View Post
EXV10 reminded us of the hacking option. I think this means using the chart to test the numbers. I appreciate the reminder. I do have that post earmarked. I am reserving that option for last, because I do not understand how to use the chart. Lynsta
the way I used the chart:
If you have not disconnected the battery as in my previous post you might just find a previous owner code. So disconnect all batteries for about 15 minutes to allow the security to reset to the factory setting.
Throw out all simple #'s. 11111 33333 12345 etc.
Then I started in the middle of the sheet and worked to the front.
Consider each button to be 0,1,2,3,4 forget the 5,6,7,8,9
After each attempt press 34 together to lock the doors which will clear any previous trial.
  #452 (permalink)
Old 05-10-2009, 02:04 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Just punch all the #'s in and when it opens backtrack 5 places.
  #453 (permalink)
Old 05-11-2009, 03:37 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE. 1 is gaining momentum as a positive member of FTE.
Here's a lil tutorial with pics on where to look and my method for seeing the sticker. I threw this together after a good tip from another member on here. The pics seem to really help with knowing what to look for.
http://www.ford-trucks.com/forums/66...er-method.html
__________________
03 Excursion Limited SOLD!!! Shopping for an 08+ 6.4 Super Duty
99 Camaro SS, Procharged, Forged 370, LS6 Intake, TH400/Brake, Fabbed 9", Kooks, Yella Terra, etc.
96 Impala SS, K&N, Hyperjunk Programing, 160 thermo, Muffler Detete, TV/DVD yadda...
88 Cutlass Supreme Classic, Forged 331, 11:1, Open Headers, TH350, Stupid Big Cam
  #454 (permalink)
Old 05-14-2009, 08:53 PM
cexcursion00 cexcursion00 is offline
cexcursion00 is starting off with a positive reputation.
Could someone send me the code sheets please? I am new at this sight. cumminspower@comcast.net
  #455 (permalink)
Old 05-14-2009, 10:31 PM
EXv10's Avatar
Quote:
Here it is;
Weak security in our daily lives@Everything2.com
  #456 (permalink)
Old 05-17-2009, 01:33 PM
al52269 al52269 is offline
al52269 is starting off with a positive reputation.
Door Code Location...
I actually found the door code behind the fuse box area (Driver Side) on my brother’s 2000 Ford Expedition EB. There is a big white sticker with 5 numbers starting with number 1####. Hope this helps...
  #457 (permalink)
Old 05-17-2009, 03:39 PM
EXv10's Avatar
That's great but I don't think they put them on the 2000 and '01 Ex's
  #458 (permalink)
Old 05-17-2009, 04:23 PM
medic152's Avatar
medic152 medic152 is offline
medic152 is starting off with a positive reputation.
Door Code
I had the same problem on my 2000 EX. After looking all over under the dash for it I took it down to the local dealer and they hooked it up to the computer and had my code in less than 5 minutes. They didn't charge me to get it either.
Brad
  #459 (permalink)
Old 05-20-2009, 11:43 PM
motopsyko32's Avatar
motopsyko32 motopsyko32 is offline
motopsyko32 is starting off with a positive reputation.
need the cheat sheet please...
motopsyko32 AT bellsouth dot net
  #460 (permalink)
Old 05-21-2009, 12:24 AM
EXv10's Avatar
It's on post 455 above here.
  #461 (permalink)
Old 06-07-2009, 04:48 PM
KeystoneHomeOK's Avatar
KeystoneHomeOK KeystoneHomeOK is offline
KeystoneHomeOK is starting off with a positive reputation.
I just bought a 2001 Expedition XLT with no manuals and I had no way how to find the keypad code. Using the info from this thread I went out to the driveway, looked at the firewall behind the fuse panel, and there it was!
Thanks for all the good info!
Troy
  #462 (permalink)
Old 06-07-2009, 05:35 PM
EXv10's Avatar
That dispells my theory about no #s on the 00 and 01. Maybe they started putting them on in late '01.
  #463 (permalink)
Old 06-07-2009, 11:30 PM
It may also be the difference between the 1/2 ton and 3/4 ton chassis. Just my 2cw....
  #464 (permalink)
Old 06-07-2009, 11:35 PM
EXv10's Avatar
I didn't see that you had an Expy.
  #465 (permalink)
Old 06-20-2009, 11:41 PM
Scottwoo Scottwoo is offline
Scottwoo is starting off with a positive reputation.
Mine was behind white insulation looking stuff...easier for me to find throught the trash bag holder. used screwdriver to move the insul and it was upside down.
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
