Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #421 (permalink)
Old 04-10-2009, 10:32 PM
arhuranna arhuranna is offline
arhuranna is starting off with a positive reputation.
Hello,
I would like a copy of the codes. Thanks in advance.
Mitch
  #422 (permalink)
Old 04-20-2009, 12:14 AM
lynsta lynsta is offline
lynsta is starting off with a positive reputation.
We can't find it on our '02 Excursion Limited. Has anyone found it on this rig? Lynsta
  #423 (permalink)
Old 04-24-2009, 08:44 AM
SARGE/AF's Avatar
SARGE/AF SARGE/AF is offline
SARGE/AF is starting off with a positive reputation.
You know I have not seen anyone mention in here that Ford also says to look in 2 other places, It says this same thing in my owners manual.
1) on the computer box under the hood
2) Right/Passenger side of vehicle behind kick plate where the fuel cutoff switch is
Sarge
  #424 (permalink)
Old 04-24-2009, 10:48 PM
Thank you. We do not have a book. We will look in those places.
  #425 (permalink)
Old 04-25-2009, 08:34 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Note this does not apply to a 2000
  #426 (permalink)
Old 04-25-2009, 10:42 AM
What does not apply ? I have a 2002. Lynsta
  #427 (permalink)
Old 04-27-2009, 06:49 AM
SARGE/AF's Avatar
I have been really busy between PGR and a family member that lost most everything they own to a fire for the last few weeks, but I will try to get my owners manual scanned and posted in here.
Sarge
  #428 (permalink)
Old 04-27-2009, 07:49 AM
vettdvr's Avatar
The 2000 doesn't have the code on the box. I found the box but never found the code anywhere on the truck.
  #429 (permalink)
Old 05-05-2009, 11:47 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
can't delete
  #430 (permalink)
Old 05-06-2009, 08:16 PM
daddyd05x daddyd05x is offline
daddyd05x is starting off with a positive reputation.
Just found it on my 05 x and it was a piece of cake. Did not remove anything and with a long flex mirror and a good light I found the black box up towards the radio and the sticker was on top so I used the mirror and got the numbers. Tried them and they worked. Took about 2 minutes to get myself situated in the right position to see. I just went up by the gas pedal.
  #431 (permalink)
Old 05-06-2009, 08:17 PM
Thanks to everyone for all the great info on this. Without this I probably would have paid the dealer a ton of money for the code
  #432 (permalink)
Old 05-06-2009, 08:33 PM
EXv10's Avatar
The 2000 and I think the 01 doesn't have it anywhere on the truck but some say it is behind everything on the gem box on the left of the steering wheel. You can print out that code; Weak security in our daily lives@Everything2.com
and it should take 20 minutes or less to find it by punching the #s......Click on the word "weak".
  #433 (permalink)
Old 05-06-2009, 09:10 PM
topgun35's Avatar
topgun35 topgun35 is offline
topgun35 is starting off with a positive reputation.
my 05 x was up behind where the ashtray would be up in the dash towards the driver side
  #434 (permalink)
Old 05-07-2009, 11:32 PM
TX Silver TX Silver is offline
TX Silver is starting off with a positive reputation.
Got tired of looking, so I started on the sheet. I modified it so that I could enter the codes 35 at a time (since that's the cutoff for the anti-theft feature). Got lucky and found the code after five lines. Unfortunately it's the code programmed by the previous owner. I guess that will work until I go through the rest of the numbers.
Big thanks to whoever thought to put that list together.
TX
  #435 (permalink)
Old 05-07-2009, 11:47 PM
EXv10's Avatar
TX
Great! I would leave well enough alone. You have to erase your code and then it requires the original code to program your own new code. But I guess you could find the original code after you erase this one and go from there.
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
