cbradford, I don't quite understand how to read #395. Is this the same format as the macro that everyone has been getting via email? How do I use this?
So, let me see if I got this. The idea is to take this list, and start punching in the numbers, beginning with the first five numbers, and then going across the list adding one number each time until the door unlocks? According to the link where this list is, the keypad doesn’t care if you put extra numbers in the front of the sequence, as long as you get the five that are needed in the sequence. Also, are the even numbers irrelevant?
I know a lot of people say this has worked, but I feel a little silly thinking about standing there punching these numbers in trying to break this code. I can’t believe that Ford doesn’t have this number somewhere on the vehicle for 02 and older ones.
Yes just start punching numbers and follow the list starting from upper left and move right (just like reading).
Yes it has been indicated in this thread that the code is located on a module under the dash and if you read this whole thread you would understand that, some have even posted pictures.
I went the route of going to the dealer and for $18 they plugged there laptop in and gave me the code in less than 2min, I was charged $18 because I did not purchase the EX from them.
Yeah, cbradford, I saw all the info about it being on a sticker, and I had heard that about a year ago. Could not find it on my ’00, as many have also said. If I could find a dealer that would do it for 18 to 20 bucks, I would be there. The dealers in my area START at $75 for the hook up. Does anybody know if a OBDII code reader, scanner or programer can pull the codes?
Hey,
First off this is the best forum ever! Second I thought I'd post where I found mine on my 05 F250. I didn't even have to take anything apart. Just open the ash tray and look behind with a flashlight. I found a large white sticker with the code. I had to reach in and move a wire out of the way to read it(and it was upside down), but had it in about 2 minutes. It was easiest to put the center console up just for more room for me to lay sideways, but it was right there!!
I've got an 04' F-250 lariat and mine was on a black box on the firewall. The tip of the straw is basicly pointing to the area where mine was at. I had to take off the trash bag hanger and move a piece of white insulation with a stick cause my arm was getting in the way while trying to hold the insulation out of the way.
ok so the pic didnt show up but the area im talking about is just left of the trash bag holder below the radio
The codes worked for me on an my 06 F150 Lariat. Was about ready to give up about 3/4 the way down the page when she poped open! Thanks guys for the thread!!
I punched in every number on the list cbradford linked but i wouldn open, so i pulled out my trash bag hanger and the cup hoder and there it was on white sticker aboute 15" in a little to the left from the cupholder, found it in 10 min. its a 04 250 lariat
so i searched my code in the codelist and IT WAS THERE!!! the code was almost at the end and i was puching wrong all the time because my fingers must been frozen inside.
keyless keypad code location for 2000 F-150 extended cab
I would like to thank everyone who posted on this topic, saved me $40.00
For the 2000 F-150 Lariat extended cab (no tools needed) !!!
The keypad code is printed in bold black print on a white sticker attached to an off white colored box just behind the emergency brake pedal. The box is as far left as possible and mounted facing downward towards the floor.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
