Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #316 (permalink)
Old 01-31-2008, 07:50 PM
MUD BUGGY MUD BUGGY is offline
MUD BUGGY is starting off with a positive reputation.
do you know where the fuse is? i wonder if thier is a battery in the key pad!
  #317 (permalink)
Old 01-31-2008, 07:52 PM
pdx02's Avatar
pdx02 pdx02 is offline
pdx02 is starting off with a positive reputation.
I thought i read it was hard wired. I am not sure but mine does not light up or anything when I press it. I am stumped and want to use it. It's a great feature.
  #318 (permalink)
Old 01-31-2008, 11:19 PM
MANSVANF350 MANSVANF350 is offline
MANSVANF350 is starting off with a positive reputation.
In my '04 f-250 thru 550 manual the batterie replacement procedure is on page 80-82
it also tells you how to program your key pad .
1 It says " to make sure your rig is electronicly locked
2 put key in ign.
3 turn key from lock to off possition
4 cycle 8 times between on and off possition ( the 8th turn must end up on the on side
5 doors will cycle ie. lock then un lock
6 within 20sec. program keyless pad by pressing 7/8&9/0 together
7 door will then cycle again confirming programingmode has been activated
8 within 20 sec press any button on your remote ( if you take longer than 20 sec you'll have to start over
9 door locks will cycle again conf. remote was programed
10 repeat step8 for each remote
11 turn rig off after programing pad and remotes
12 door will once again cycle to confirm that the program mode has exited
  #319 (permalink)
Old 01-31-2008, 11:51 PM
dougger222 dougger222 is offline
dougger222 is starting off with a positive reputation.
A couple years ago while getting new keys programed for the remote start had Ford run the numbers for the keypad. It ended up being a very easy to remember combination.
With the actuator now out it doesn't really matter!
__________________
00 Excursion Limited 4x4 powerstroke
99 F350 Lariat crew cab dually 4X4 powerstroke
99 F250 XLT x-cab 4X4 powerstroke
65 Mustang 289 V8 4brl 69 GTO 400 4spd
86 GLHS #284/500 99 Neon R/T
04 14 ft dump trailer 04 20 ft car hauler 98 12ft enclosed trailer
  #320 (permalink)
Old 02-05-2008, 12:13 PM
Mulepick's Avatar
Mulepick Mulepick is offline
Mulepick is starting off with a positive reputation.
Great info. Now, how do I remove the radio?
Bob
__________________
2006 F-250 crew cab, SWB, SRW, PSD, Lariat/FX4, A/T, ARP studs, ISSPRO Pyro and Trans temp,Fumoto,
Mobil 1, BFG Radial T/A 285/70-17s,Helwig rear sway bar,Ride rite air bags/onboard compressor, coolant filter
2004 Lance 820 camper
  #321 (permalink)
Old 02-05-2008, 01:48 PM
VaSheriff VaSheriff is offline
VaSheriff has a good reputation on FTE. VaSheriff has a good reputation on FTE.
Quote:
Bob
Best way is with these special prongs....
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
Finish nails can be used. Insert 2 in each side.
__________________
SQUIRRELS -- nature's little speedbumps!
  #322 (permalink)
Old 02-05-2008, 02:18 PM
Mulepick's Avatar
My truck ain't got no stinkin' holes...
__________________
  #323 (permalink)
Old 02-06-2008, 11:23 AM
ukmat71's Avatar
ukmat71 ukmat71 is offline
ukmat71 is starting off with a positive reputation.
Quote:
Originally Posted by VaSheriff
I used nylon tie wraps (i think thats what they are called in the US)
then get your fingers in the tape player hole & pull away.
__________________
00 Excursion XLT 4x4 6.8 V10 for family
95 Mitsubishi Lancer Evolution 4x4 GSR for fun
  #324 (permalink)
Old 03-03-2008, 08:59 PM
ffmedic97 ffmedic97 is offline
ffmedic97 is starting off with a positive reputation.
Thumbs up entry code
Thank you very much used your pics and wording and found my code
jeff
  #325 (permalink)
Old 03-03-2008, 11:20 PM
workaholic2001 workaholic2001 is offline
workaholic2001 is starting off with a positive reputation.
Codes for 2002 x
locked both keys in the car have no code can someone e-mail the codes for a 2002 x briand@uniqueturf.com
  #326 (permalink)
Old 03-12-2008, 07:56 PM
abmorejon abmorejon is offline
abmorejon is starting off with a positive reputation.
Smile 2006 F250 Computer Module for factory code
Thank you so much for the information on where to find the module for the keyless entry factory code. Mine was located behind the radio area and behind the insulation. It was not white, it was black but it did have the five digit number. Dealer wanted to charge me $90 to get it for me.
  #327 (permalink)
Old 03-12-2008, 10:00 PM
Mulepick's Avatar
No. Really. My '06 Lariat doesn't have any radio holes. Do I have to pull the whole fake-wood plate to get the radio out? If so, does it just pull out or what?
Bob
__________________
  #328 (permalink)
Old 03-12-2008, 11:46 PM
I was able to get to it thru the fuse cover plate located under the steering wheel and I also took off the small drawer next to that. I did not have to remove anything other dash parts or radio. It took me three nights to find it, but I finally did in the area of the radio, up by the fire wall, behind the insulation. Good Luck.
  #329 (permalink)
Old 03-17-2008, 01:27 PM
joeracer321 joeracer321 is offline
joeracer321 is starting off with a positive reputation.
I would greatly appreciate it, if someone could please email this sheet with the keypad codes on it. I spent an hour yesterday looking for the sticker and it appears it has already been peeled off! My email is Joe306sc@yahoo.com Thanks in advance!
  #330 (permalink)
Old 03-17-2008, 01:48 PM
ukmat71's Avatar
sent it , link below for anyone else that need it
http://cid-4d2c86be24b462f6.skydrive...se.aspx/Public
__________________
Tags
1996 , 350 , 500 , auto , code , codes , default , door , f250 , ford , keyless , keypad , module , rap , reset
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
